PIC16F877A DS1302芯片驱动
发布者:平静宁静最新更新时间:2016-11-04 来源: eefocus关键字:PIC16F877A  DS1302  芯片驱动 手机看文章 扫描二维码
随时随地手机看文章
  1. #include
  2. typedef unsigned char uchar;
  3. typedef unsigned int uint;
  4. #define rs_h PORTC|=0x01
  5. #define rs_l PORTC&=0xfe
  6. #define rw_h PORTC|=0x02
  7. #define rw_l PORTC&=0xfd
  8. #define en_h PORTC|=0x04
  9. #define en_l PORTC&=0xfb
  10. #define rst_h PORTC|=0x08
  11. #define rst_l PORTC&=0xf7
  12. #define sck_h PORTC|=0x10
  13. #define sck_l PORTC&=0xef
  14. #define io_h PORTC|=0x20
  15. #define io_l PORTC&=0xdf
  16. #define SECADD 0X80//秒寄存器地址
  17. #define MINADD 0x82
  18. #define HRADD 0x84
  19. #define DATEADD 0x86
  20. #define MONTHADD 0x88
  21. #define DAYADD 0x8a
  22. #define YEARADD 0x8c
  23. #define CONTROLADD 0x8e
  24. #define PORT (PORTB)
  25. void delayms(uint x);
  26. void lcd_com(uchar com);
  27. void lcd_dat(uchar dat);
  28. void lcd_write(uchar c,uchar r,uchar dat);
  29. void lcd_init(void);
  30. void Ds1302Init(void);
  31. void WriteByte(uchar dat);
  32. uchar ReadByte(void);
  33. uchar BCDtoDex(uchar dat);
  34. uchar DextoBCD(uchar dat);
  35. uchar ReadByte(void);
  36. void Ds1302Write(uchar add,uchar dat);
  37. uchar Ds1302Read(uchar add);
  38.
  39. void main(void)
  40. {
  41.     uchar sec,min,hr,date,month,day,year;
  42.     TRISB=0x00;
  43.     TRISC&=0xc0;
  44.     lcd_init();
  45.     Ds1302Init();
  46.     while(1)
  47.     {
  48.         sec=Ds1302Read(SECADD);
  49.         min=Ds1302Read(MINADD);
  50.         hr=Ds1302Read(HRADD);
  51.         date=Ds1302Read(DATEADD);
  52.         month=Ds1302Read(MONTHADD);
  53.         day=Ds1302Read(DAYADD);
  54.         year=Ds1302Read(YEARADD);
  55.
  56.         sec=BCDtoDex(sec);
  57.         min=BCDtoDex(min);
  58.         hr=BCDtoDex(hr);
  59.         date=BCDtoDex(date);
  60.         month=BCDtoDex(month);
  61.         day=BCDtoDex(day);
  62.         year=BCDtoDex(year);
  63.
  64.         lcd_write(0,1,0x32);
  65.         lcd_write(0,2,0x30);
  66.         lcd_write(0,3,0x30+year/10);
  67.         lcd_write(0,4,0x30+year%10);
  68.         lcd_write(0,6,0x30+month/10);
  69.         lcd_write(0,7,0x30+month%10);
  70.         lcd_write(0,9,0x30+date/10);
  71.         lcd_write(0,10,0x30+date%10);
  72.         lcd_write(0,14,0x30+day);
  73.         lcd_write(1,4,0x30+hr/10);
  74.         lcd_write(1,5,0x30+hr%10);
  75.         lcd_write(1,7,0x30+min/10);
  76.         lcd_write(1,8,0x30+min%10);
  77.         lcd_write(1,10,0x30+sec/10);
  78.         lcd_write(1,11,0x30+sec%10);
  79.         delayms(1005);//1ms
  80.     }
  81.
  82. }
  83. void Ds1302Init(void)
  84. {
  85.     rst_l;
  86.     sck_l;
  87.     Ds1302Write(CONTROLADD,0);//关闭写保护
  88.     Ds1302Write(MINADD,DextoBCD(06));
  89.     Ds1302Write(HRADD,DextoBCD(19));
  90.     Ds1302Write(DATEADD,DextoBCD(20));
  91.     Ds1302Write(MONTHADD,DextoBCD(5));
  92.     Ds1302Write(DAYADD,DextoBCD(7));
  93.     Ds1302Write(YEARADD,DextoBCD(12));
  94.     Ds1302Write(SECADD,DextoBCD(30));//写秒,同时启动时钟
  95. }
  96. void WriteByte(uchar dat)//上升沿输出
  97. {
  98.     uchar i;
  99.     TRISC&=0xdf;
  100.     for(i=8;i>0;i--)
  101.     {
  102.         sck_l;//低电平时数据线可变
  103.         if(dat&0x01)
  104.             io_h;
  105.         else
  106.             io_l;
  107.         sck_h;
  108.         dat>>=1;
  109.     }
  110. }
  111. uchar BCDtoDex(uchar dat)//BCD码转十进制
  112. {
  113.     uchar i;
  114.     i=dat/16;
  115.     dat%=16;
  116.     i=i*10+dat;
  117.     return i;
  118. }
  119. uchar DextoBCD(uchar dat)//十进制转BCD码
  120. {
  121.     uchar i;
  122.     i=dat/10;
  123.     dat%=10;
  124.     i=i*16+dat;
  125.     return i;
  126. }
  127. uchar ReadByte(void)//下降沿输出
  128. {
  129.     uchar i;
  130.     uchar dat;
  131.     TRISC|=0x20;
  132.     for(i=8;i>0;i--)//要考虑之前写完后的状态,第一次进入此循环体即有下降沿
  133.     {
  134.         dat>>=1;
  135.         sck_l;
  136.         if(PORTC&0x20)
  137.             dat|=0x80;
  138.         sck_h;
  139.     }
  140.     return dat;
  141. }
  142. void Ds1302Write(uchar add,uchar dat)
  143. {
  144.     rst_l;
  145.     sck_l;
  146.     rst_h;
  147.     WriteByte(add);//最低位置0表示写
  148.     WriteByte(dat);
  149.     rst_l;
  150. }
  151. uchar Ds1302Read(uchar add)
  152. {
  153.     uchar dat;
  154.     rst_l;
  155.     sck_l;
  156.     rst_h;
  157.     WriteByte(add+1);//地址最低位置1表示读
  158.     dat=ReadByte();
  159.     rst_l;
  160.     return dat;
  161. }
  162. void delayms(uint x) //8M晶振下,延时1ms
  163. {
  164.     uint y,z;
  165.     for(y=x;y>0;y--)
  166.         for(z=220;z>0;z--);
  167. }
  168. void lcd_init(void)//LCD1602初始化
  169. {
  170.     lcd_com(0x38);
  171.     lcd_com(0x0c);
  172.     lcd_com(0x06);
  173.     lcd_write(0,5,0xb0);
  174.     lcd_write(0,8,0xb0);
  175.     lcd_write(1,6,0x3a);
  176.     lcd_write(1,9,0x3a);
  177. }
  178. void lcd_com(uchar com)//向LCD1602写命令
  179. {
  180.     rs_l;
  181.     rw_l;
  182.     PORT=com;
  183.     delayms(1);
  184.     en_h;
  185.     delayms(1);
  186.     en_l;
  187. }
  188. void lcd_dat(uchar dat)//向LCD1602写数据
  189. {
  190.     rs_h;
  191.     rw_l;
  192.     PORT=dat;
  193.     delayms(1);
  194.     en_h;
  195.     delayms(1);
  196.     en_l;
  197. }
  198. void lcd_write(uchar c,uchar r,uchar dat)//向LCD1602指定行、指定列、写数据
  199. {
  200.     lcd_com(0x80+0x40*c+r);
  201.     lcd_dat(dat);
  202.     delayms(1);
  203. }
关键字:PIC16F877A  DS1302  芯片驱动 引用地址:PIC16F877A DS1302芯片驱动
上一篇:PIC16F877A 的sleep mode
下一篇:PIC16F877A 外部中断RB0 ,RA0点亮LED
推荐阅读最新更新时间:2024-03-16 15:19
pic16f877a.h中文注释
存放路径:在PICC软件hi-tech安装目录下,?:\Microchip\cc8.05\include,找到pic1687xa.h,里面即有 以下是头文件内容及详细注释: /* * Header file for the Microchip * PIC 16F873A chip * PIC 16F874A chip * PIC 16F876A chip * PIC 16F877A chip * Midrange Microcontroller */ #if defined(_16F874A) || defined(_16F877A) #define __PINS_40 #endif static volatile unsign
[单片机]
51单片机——SPI、DS1302时钟 C语言入门编程
SPI: 写时序: 在控制指令字输入后的下一个SCLK时钟的上升沿时,数据被写入DS1302, 数据输入从低位(位0)开始。(先写低位) 读时序: 在紧跟8位的控制指令字后的下一个SCLK脉冲的下降沿读出DS1302的数据,读出数据时从低位0位到高位7。(先读低位,读取后将IO设置为0,否则读出的数据会出错) DS1302: DS1302是DALLAS公司推出的涓流充电时钟芯片,内含有一个实时时钟/日历和31字节静态 RAM,通过简单的串行接口与单片机进行通信。实时时钟/日历电路提供秒、分、时、日、周、月、年的信息,每月的天数和闰年的天数可自动调整。时钟操作可通过AM/PM指示决定采用24或12小
[单片机]
51单片机——SPI、<font color='red'>DS1302</font>时钟 C语言入门编程
51单片机实验15:DS1302时钟模块应用
开发板DS1302模块电路图如下: 目的:单片机查询DS1302时钟模块时间,并将其显示在数码管上。 DS1302的初始化时间为2019年1月1日12:00(星期二) #include reg52.h #include dse1302.h sbit LSA=P2^2; sbit LSB=P2^3; sbit LSC=P2^4; uc code x ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; uc tim ; void delay(uc x) { uc i,j; for(i=1;i =x;i++) for(j=1;j =110;j++);
[单片机]
51单片机实验15:<font color='red'>DS1302</font>时钟模块应用
PIC16f877A读写24c02程序
P IC 16f877A读写24c02程序 #include pic.h #include string.h #define uchar unsigned char #define uint unsigned int static volatile unsigned char a CC @ 0x20; //发收数据暂存器 static volatile bit acc0 @ (unsigned)&acc*8+0; //接收 static volatile bit acc7 @ (unsigned)&acc*8+7; //发送 static volatile unsigned char err
[单片机]
DS1302-演示代码
参考DS1302数据手册,尽管数据手册是英文,但是很有帮助,再结合网上众多的代码写出了下面这个例子,除了涓流充电(trickle charger)功能没使用外,内部的RAM和寄存器功能都使用到了,包括多字节方式(burst mode)。自认为我写的比网上大多数程序清晰,当然已经硬件测试过了。 1 #include reg52.h 2 3 /*DS1302部分*/ 4 5 //全部为写入地址,读取地址需要+1 6 #define YEAR 0x8c 7 #define MON 0x88 8 #define DATE 0x86 9 #define DAY 0x8a 10 #define HOUR 0x84
[单片机]
DS1302+AT89C2051控制的红外遥控LED电子钟设计
自制LED电子钟在很多电子类报刊杂志上都可以见到,但多数在断电后要重新设置时间等参数,给使用带来不便。也有用电池作为备用电源的,但往往体积较大。本文介绍的LED电子钟克服了上述弊端,加上采用家电通用的红外遥控器进行控制,使用方便。该电子钟有一路闹铃输出,可以通过遥控器设置闹铃时间及闹铃允许。   一、工作原理   实时时钟芯片DS1302采用串行数据传输,可为掉电保护电源提供可编程的充电功能,也可以关闭充电功能,芯片采用32768Hz晶振。   AT89C2051作为主控芯片,其功能一是对接收到的红外遥控编码进行判断识别,并进行相应的处理;二是定期读取DS1302中的时间,并把小时和分钟送显示;三是比较设置的闹铃时间与实时时间,如
[单片机]
<font color='red'>DS1302</font>+AT89C2051控制的红外遥控LED电子钟设计
基于DS1302数字芯片的“电子台历”设计调试心得
DS1302是一款价格低廉,精度高的时钟芯片;该芯片具有年、月、日、分、秒、闰年、电池涓流充电,等优秀的功能,其芯片发明是DALLS 达拉斯 公司的产品,在电脑、相机等需要时间的数字产品中都有用到。于是本人针对该芯片准备设计一款具有 实时时间、室温测量、年月日实时显示、国际节日提醒功能、自动背光调整 为一体的电子台历。 电子台历原理图在本月15号设计完成,PCB电路板图于16号完成并发外打样。由于时间仓促在第一款PCB设计排板时,PCB走线比较杂乱,4天后收到成品PCB,于是开始进入焊接调试阶段;通过半小时的焊接,一个半成品完成,然而通过STC-ISP在线下载后,12684液晶屏能进入初始程序,同时能实时地测
[单片机]
基于<font color='red'>DS1302</font>数字芯片的“电子台历”设计调试心得
时钟程序(LED+DS1302+AT89S52)
#include reg51.h /*************************ds1302与at89s52引脚连接********************/ sbit T_RST=P3^5; sbit T_CLK=P3^6; sbit T_IO=P3^7; sbit ACC0=ACC^0; sbit ACC7=ACC^7; unsigned char seg ={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09}; //0~~9段码 /******************DS1302:写入操作(上升沿)**
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
