这里是接前面的文章
PA3 ADC1的通道3
下面是完整的程序
__IO uint16_t AdcValue =0;
*函 数 名:bsp_InitAdc
*函数功能:ADC1初始化
*形 参:无
*返 回 值:无
void bsp_InitAdcDMA(void);
void bsp_InitAdc(void)
GPIO_InitTypeDef GPIO_InitStructure;
ADC_CommonInitTypeDef ADC_CommonInitStructure;
ADC_InitTypeDef ADC_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);//使能GPIOA时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);//使能ADC时钟
bsp_InitAdcDMA();
/*初始化ADC1通道3 的IO口*/
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;/*模拟输入*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;/*通道3*/
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;/*不带上下拉*/
GPIO_Init(GPIOA,&GPIO_InitStructure);/*初始化*/
/*通用控制寄存器的配置*/
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;/*DMA失能*/
ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;/*独立模式*/
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;/*APB2的4分频 即84/4=21M*/
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;/*两个采样阶段的延时5个时钟*/
ADC_CommonInit(&ADC_CommonInitStructure);/*初始化*/
/*初始化ADC1*/
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;/*12位模式*/
ADC_InitStructure.ADC_ScanConvMode = ENABLE;/*扫描模式*/
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;/*连续转换*/
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;/*禁止触发检测 使用软件触发*/
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;/*右对齐*/
ADC_InitStructure.ADC_NbrOfConversion = 1;/*只使用1通道 规则通为1*/
ADC_Init(ADC1,&ADC_InitStructure);/*初始化*/
ADC_Cmd(ADC1,ENABLE);/*开启转换*/
ADC_RegularChannelConfig(ADC1,ADC_Channel_3,1,ADC_SampleTime_480Cycles);/*设置规则通道3 一个序列 采样时间 */
ADC_SoftwareStartConv(ADC1);/*启动软件转换*/
ADC_DMARequestAfterLastTransferCmd(ADC1,ENABLE);//源数据变化时开启DMA传输
ADC_DMACmd(ADC1,ENABLE);//使能ADC传输
*函 数 名:bsp_InitAdcDMA
*函数功能:DMA2初始化
*形 参:无
*返 回 值:无
DMA_InitTypeDef DMA_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2,ENABLE);/*DMA2的时钟使能*/
while(DMA_GetCmdStatus(DMA2_Stream0)!=DISABLE);/*等待DMA可以配置*/
DMA_InitStructure.DMA_Channel = DMA_Channel_0;/*DMA通道0*/
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_BASE+0x4C;/*外设地址*/
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&AdcValue;/*存取器地址*/
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;/*方向从外设到内存*/
DMA_InitStructure.DMA_BufferSize = 1;/*数据传输的数量为1*/
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;/*地址不增加*/
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;/*地址不增加*/
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;/*数据长度半字*/
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;/*数据长度半字*/
DMA_InitStructure.DMA_Priority = DMA_Priority_High;/*高优先级*/
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;/*循环模式*/
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;/*禁止FIFO*/
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;/*FIFO的值*/
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;/*单次传输*/
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;/*单次传输*/
DMA_Init(DMA2_Stream0,&DMA_InitStructure);/*初始化*/
DMA_Cmd(DMA2_Stream0,ENABLE);//开启DMA传输
* 函 数 名: main
* 功能说明: c程序入口
* 形 参:无
* 返 回 值: 错误代码(无需处理)
int main(void)
ST固件库中的启动文件已经执行了 SystemInit() 函数,该函数在 system_stm32f4xx.c 文件,主要功能是
配置CPU系统的时钟,内部Flash访问时序,配置FSMC用于外部SRAM
bsp_Init();
/* 进入主程序循环体 */
while (1)
if(DMA_GetFlagStatus(DMA2_Stream0,DMA_FLAG_TCIF0)!=RESET)/*传输完成*/
printf("adc0=%d ",AdcValue);
DMA_ClearFlag(DMA2_Stream0,DMA_FLAG_TCIF0);/*清零*/
bsp_DelayMS(1000);
下面是MDA的映射关系图
上一篇:STM32F407的ADC单次转换
下一篇:STM32F407的ADC之DMA多通道
推荐阅读最新更新时间:2024-03-16 15:36
