STM32串口中断接收数据
发布者:量子心跳最新更新时间:2017-11-02 来源: eefocus关键字:STM32  串口中断  接收数据 手机看文章 扫描二维码
随时随地手机看文章
数据帧满足下面格式:
帧头部(Head)
类型(Type)
长度(Length)
值(Value)
CRC校验
2字节
1字节
1字节
X字节
2字节
     0xaa  0x55
void USART6_Init (void)
GPIO_InitTypeDef    GPIO_InitStructure;
USART_InitTypeDef   USART_InitStructure;
NVIC_InitTypeDef    NVIC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART6,ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE); //修改
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;//修改
GPIO_InitStructure.GPIO_Mode    = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType   = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd    = GPIO_PuPd_NOPULL;
GPIO_InitStructure.GPIO_Speed   = GPIO_Speed_50MHz;
GPIO_Init(GPIOC,&GPIO_InitStructure);//修改
GPIO_PinAFConfig(GPIOC,GPIO_PinSource6,GPIO_AF_USART6);//修改
GPIO_PinAFConfig(GPIOC,GPIO_PinSource7,GPIO_AF_USART6); //修改
NVIC_InitStructure.NVIC_IRQChannel = USART6_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Tx|USART_Mode_Rx;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_Init(USART6,&USART_InitStructure);
USART_ITConfig(USART6,USART_IT_RXNE,ENABLE);//打开接收中断
USART_Cmd(USART6,ENABLE);
void USART6_IRQHandler()
unsigned char rCh;
static char rCnt = 0;
if (USART_GetITStatus(USART6,USART_IT_RXNE) != RESET)
rCh = USART_ReceiveData(USART6);
COM6_RecvBuf[rCnt] = rCh;
if (rCnt == 0)    //帧头0xAA
rCnt = (0xAA != rCh)?0:rCnt+1;
else if (rCnt == 1) //帧头0x55
rCnt = (0x55 != rCh)?0:rCnt+1;
else if (rCnt == 2) //类型type
//这里可以根据类型的范围进行如上的处理
rCnt++;
else if (rCnt == 3) //长度len
rCnt++;
else if (rCnt > 3) //值value
rCnt++;
if (rCnt == 6+COM6_RecvBuf[3])
rCnt = 0;
memcpy(COM6_RecvBufBck,COM6_RecvBuf,RECV_BUF_SZ);//缓冲
COM6_RecvFin = 1;  //通知主循环处理
int  main(void)
int i;
//代码段1
while (1)//该循环不能太慢,否则数据缓冲区会被部分修改
//代码段2
if (COM6_RecvFin == 1)
COM6_RecvFin = 0;
CMD_Analysis();//分析接收到的这帧数据
//代码段3
return  0;
关键字:STM32  串口中断  接收数据 引用地址:STM32串口中断接收数据
上一篇:STM32的时钟的修改方法(HSE使用16M无源晶振时)
下一篇:STM32 BKP备份寄存器介绍
推荐阅读最新更新时间:2024-03-16 15:42
STM32单片机学习笔记(9):定时器中断
项目简介 利用CubMX生成基于32单片机的HAl库工程,然后编写程序在proteus上仿真验证。本项目最适合没有开发板的同学学习,零成本利用仿真软件率先入门STM32单片机。本项目利用CubMX创建一个32工程,用以实现定时器中断控制LED灯的状态转换的功能,并在Proteus中进行仿真验证。 硬件模块 STM32F103R4 LED 软件工具 CubMX Proteus KEIL 电路连接图 工作流程 首先,创建一个CubMX工程。这里选择的是STM32F103R4型号的单片机。下图是时钟树的设置,这个根据自己习惯设置就好,这里的时钟频率,也就是定时器时钟频率是8MHz. 介绍定时器发生中断时间的计算方法:
[单片机]
<font color='red'>STM32</font>单片机学习笔记(9):定时器<font color='red'>中断</font>
基于STM32单片机的数据记录装置设计
引言 本文针对电动汽车研究的实际需求,设计一款数据记录装置,该数据记录装置是搭建在电池能量管理系统基础上的,通过与能量管理系统通信,记录电动汽车实际运行时电池的外部状态(如:电池电压、电流、温度等),一方面为了研究电池的工作特性,另一方面为了对能量管理系统的工作情况做验证,为电动汽车动力电池的理论研究提供数据支持。 1 系统总体设计 本数据记录装置的设计包括硬件设计与软件设计两方面,软件设计主要包括数据接收的编程以及数据存储的编程,而硬件设计主要有几个方面:主控芯片的选择、复位功能的实现、电源模块、实时时钟、通信模块以及SD卡连接等。主控芯片是控制系统的核心,它内部所集成的模块越多,就能省去更多的外部电路,使得电路的设
[电源管理]
基于<font color='red'>STM32</font>单片机的<font color='red'>数据</font>记录装置设计
STM32 TIM2重映射
stm32的TIM2的端口使用组合有下面四种: 1.当不重映射时,默认TIM2四个的IO口是PA0、PA1、PA2、PA3 2.要使用PA15、PB3、PA2、PA3的端口组合,要调用下面的语句进行部分重映射: RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); //重映射必须要开AFIO时钟 GPIO_PinRemapConfig(GPIO_PartialRemap1_TIM2, ENABLE); 3.要使用PA0、PA1、PB10、PB11的端口组合,要调用下面的语句进行部分重映射: RCC_APB2PeriphClockCmd(RCC_APB2Perip
[单片机]
STM32的待机唤醒实验
很多单片机具有低功耗模式,默认情况下,系统复位或上电复位后,微控制器进入运行模式。在运行模式下,HCLK 为 CPU 提供时钟,并执行相应程序。当需要实现低功耗项目的时候,可以利用多种低功耗模式来节省功耗。 运行模式下降低功耗方式 降低系统时钟速度 不使用 APBx 和 AHB 外设时,将对应的外设时钟关闭 STM32 提供了 3 种低功耗模式 睡眠模式( 内核停止,外设如NVIC,系统时钟Systick仍运行。) 停止模式(所有时钟都已停止。1.8V内核电源工作。PLL,HIS和HSE RC振荡器功能禁止。寄存器和SRAM内容保留) 待机模式( 1.8V内核电源关闭。只有备份寄存器和待机电路维持供电。寄存器和SRAM内容
[单片机]
<font color='red'>STM32</font>的待机唤醒实验
STM32双核板的应用设计与ISP的从机软件升级
引言 在单片机的应用设计中,常常会遇到如下问题:其一,某一熟悉类型的单片机功能可用,性价比也很好,但限于某种内部资源(如串口数、A/D路数等)不足,不得不选用更高档或不太熟悉的单片机,造成资源的浪费和开发周期的延长。其二,在海洋远程监测等重要领域,对控制器的可靠性要求较高,而单片机存在死机的可能性,即使可以通过配备看门狗来避免这种情况,但这种 粗暴 的复位方式并不合理(首先,复位打乱了正常的数据采集和处理工作,导致重要数据丢失;其次,即便能记录下复位时间和次数,但复位原因和复位前状态等信息无法侦测,一些本该解决的BUG被掩盖,导致频繁复位)。其三,由于开发周期不足或测试不充分,导致设备投入运行后出现故障,而这些故障往往通过软件升级的
[单片机]
<font color='red'>STM32</font>双核板的应用设计与ISP的从机软件升级
STM32 GPIO使用步骤 ST3.0.0库
初始化一个普通IO的步骤 1:GPIO_InitTypeDef GPIO_InitStructure定义一个结构体,用于初始化IO 2:使能IO时钟,STM32 的IO都是高速IO。 分为两种情况 第一种是IO为高速时钟: void RCC_APB2PeriphClockCmd(uint32_t RCC_APB2Periph, FunctionalState NewState) 第二种是IO为低速时钟 void RCC_APB1PeriphClockCmd(uint32_t RCC_APB1Periph, FunctionalState NewState) 3:GPIO_InitStructure选定具体IO端口,用户
[单片机]
STM32学习笔记-ADC采集-串口2发送至上位机
串口2的配置(一根杜邦线不行纠结了半天) void USART2_Initialise( u32 bound ) { GPIO_InitTypeDef GPIO_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; USART_InitTypeDef USART_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO,ENABLE); /* Enable the USART2 Pins Software Remapping */ RCC_APB2
[单片机]
<font color='red'>STM32</font>学习笔记-ADC采集-<font color='red'>串口</font>2发送至上位机
STM32定时器的几种用法
一、常用的定时功能 (1)基本、通用、高级定时器都有最基本的定时功能,定时功能用到的函数如下: HAL_ TI M_Base_Init 初始化定时,包括分频、 预装值等。 HAL_TIM_ConfigClockSource 选择定时器的 时钟 源 HAL_TIM_Base_Start_IT 开始定时器 HAL_TIM_PeriodElapsedCallb ac k 超时后的回调函数 (2)Cubemx的配置,不管什么定时器,都是这个配置,注意开启中断,计算好最终的定时器时钟 (3)代码片段 1 void MX_TIM12_Init(void) 2 { 3 TIM_ClockConfigTypeDef sClo
[单片机]
<font color='red'>STM32</font>定时器的几种用法
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
更多每日新闻
