基于Si270x降EMI音频D类放大技术
最新更新时间:2011-09-29来源: 互联网关键字:Si270x  EMI音频  D类放大 手机看文章 扫描二维码
随时随地手机看文章
本文介绍了Si2704/05/06/07主要特性, 功能方框图, 典型应用电路图和材料清单,以及多种系统配置图与Si270x-EVB D类放大器开发套件主要特性.
Silabs公司的Si2704/05/06/07是降EMI的数字音频处理D类放大器,集成了功率级,PWM DAC和数字音频处理(DAP),以简化低成本高效率系统的设计. Si270x具有数字输入Delta-Sigma PWM,正在申请专利的降EMI,AM波段无噪音陷波滤波器,能向3欧姆BTL输出2x5W功率,PSRR大于50dB时的效率88%,THD优于0.1%时的动态范围为95dB,主要应用在PMP/MP3坞站,手持消费类电子,有源/无线扬声器,TV和监视器以及TV声卡等.
Si2704/05/06/07应用:
PMP/MP3 docking stations
Portable consumer audio electronics
Table top and portable radios
Active/wireless speakers
TVs and monitors
TV sound bars
图1.Si2704/05/06/07功能方框图
图2.Si2704/05/06/07典型应用电路图
典型应用电路材料清单(BOM):
图3.Si270x PMP坞站系统基本配置图
图4.Si270x 带无线电和数字媒体控制的PMP坞站系统配置图
图5.Si270x立体声双向扬声器系统配置图
图6.Si270x TV声卡系统配置图
Si270x-EVB Class D Amplifier Development Kit
图7.Si270x-EVB D类放大器开发套件外形图
The Si270x Class D amplifier EVB consists of a baseboard and a daughter card. The baseboard is common and shared among all the Si270x 5 W per channel Class D audio amplifier daughter cards. The Si270x-EVB kit addresses the entire Si270x family of Class D amplifier products.
The daughter card is populated with the Si2707 Class D amplifier which provides the following:
EMI mitigation
Volume and tone controls
EQ and Dynamic Range Compressor DSP functions
Tunable noise-free notch for AM radio coexistence
The Si270x Class D amplifier EVB is supported by a full function graphical user interface (GUI) that runs on a standard PC and is connected to the EVB via USB. The baseboard includes the Si4730 AM/FM tuner, a stereo analog input, as well as an optical SPDIF input for digital audio sources. The daughter card also includes the required output filtering network. Speakers with impedances of 4 Ω and larger may be directly driven from this board; a separate line level output is provided.
The Si270x-EVB Class D Amplifier development kit includes:
Si270x Evaluation Board
External power supply
AM/FM adapter card and antennas cable
Audio cable
Documentation and software CD
关键字:Si270x  EMI音频  D类放大 编辑:神话 引用地址:基于Si270x降EMI音频D类放大技术
上一篇:三洋DC-SL迷你组合音响的改进电路
下一篇:即插即用的USB网络收音机
推荐阅读最新更新时间:2023-10-12 20:30
D类放大器及EMI抑制
   前言   在日新月异的多媒体时代,便携式电子产品,如智能电话、PDA、MP3、PMP、DSC、DVC、NB等多媒体产品,对声音质量的要求越来越严格。另外,由于此类产品为电池供电,除了要求音质的再突破外,也要求整体效率的提升,以达到高效、低功耗的设计目标。   此类产品的音频模块中,除了输入端的信号源和输出端的喇叭或耳机外,音频放大器是一个非常重要的角色。目前广   泛用于便携产品的音频放大器有AB类和D类两种。通常,AB类放大器能够提供好的音质,但效率欠佳,耗电较大;而D类放大器具有高效、低温升效应和高输出功率等特点。    理论分析   AB类放大器的工作原理类似于线性调节器,效率差而
[电源管理]
<font color='red'>D类放大</font>器及<font color='red'>EMI</font>抑制
D类放大器的几大发展趋势
D类放大器在过去的几代产品中已经得到了巨大的发展,系统设计者极大地改善了系统的耐用性并提高了其音频质量。实际上,对大多应用而言,使用这些放大器所带来的好处已经远远超过了它们的不足。   在传统D类放大器中,用控制器将模拟或数字音频信号在被集成到功率后端设备中的功率MOSFET管放大之前转换成PWM信号。这些放大器效率很高,使用很小的散热器或根本不需要散热器,且降低了对电源输出功率的要求。然而,与传统的A/B类放大器相比,它们本身也存在固有的成本、性能和EMI方面的问题,解决这些问题就是D类放大器的发展新趋势。   降低EMI   自从D类放大器诞生以来,由于其自身的轨对轨(rail-to-rail)供电开关特性而
[模拟电子]
采用新的调制技术和滤波器结构减小D类放大器的EMI
摘要:D类放大器通常具有比AB类放大器更高的效率,适合低功耗应用。然而,尽管D类放大器具有这一先天优势,但仍然不能弥补传统D类放大器所存在的缺点,即增加了成本,降低了音频性能,并且需要输出滤波。然而,近年来D类放大器技术的进步,降低了D类放大器成本,同时可以提供与AB类放大器相类似的音频性能。此外,一些新型的D类输出调制方案同时也降低许多应用中的EMI。 引言 近年来D类放大器的技术迅猛发展,最常见的莫过于应用于每个通道低于50W的低功耗产品中。在这些低功耗应用中,D类放大器相比传统AB类放大器而言有效率上的先天优势,因为D类放大器的输出级通常只处于导通或关断,
[模拟电子]
如何桥接D类放大
与传统的A类、B类或AB类线性放大器相比,D类音频放大器有许多优点。线性放大器可以在非常低的信号水平下有更高的效率,这取决于它们是如何偏置的,但随着输出信号水平的增加,这种优势消失了,D类放大器表现得更好。根据设计,D类放大器可以有更高的空闲功耗,由于开关损耗在其输出器件。由于输出电感的铁芯损耗和输出滤波电容的ESR损耗,它们还会在输出LC滤波器中遭受寄生损耗。但即使有这些限制,在大多数应用和典型的音乐占空比中,D类放大器在功耗方面的平均效率大约是它的两倍。从组件计数的角度来看,它们不那么复杂;需要更少的散热和更小的电源。他们也包装更紧凑,可以更少的成本,因为有可能削减一半的系统的热容量。 本文将着重讲解,涵盖在桥接模式下使用
[嵌入式]
如何桥接<font color='red'>D类放大</font>器
立体声10瓦D类放大器具备低失真和高EMI
  Cirrus Logic公司宣布推出立体声10瓦模拟输入D类音频放大器IC:CS3511,以拓展公司D类音频放大器产品线。CS3511是消费音频应用的理想之选,包括有源媒体扬声器、底座、混合无线电、平板显示器以及迷你家庭影院系统等。   CS3511采用先进的△-∑调制器以及拥有专利权的闭环架构和扩展频谱开关控制技术。与其他立体声10瓦D类放大器IC相比,CS3511可实现极低的失真性能,并可大幅降低电磁干扰(EMI)。扩展频谱开关控制技术确保器件可适应音频输入信号,并实现比传统PWM方法更高的分辨率。CS3511具有可降低开关功率MOSFET固有非线性的持续反馈和前馈路径,同时还可提高设备在高开关频率下的稳定性。因此,在
[模拟电子]
Vishay新款双片电感器可为D类放大器提供稳定的性能保障
器件通过AEC-Q200认证,可在+155℃高温下工作 日前,Vishay Intertechnology, Inc.(NYSE 股市代号:VSH)宣布,推出3232外形尺寸的新器件--- IHLD-3232HB-5A ,扩展其IHLD系列超薄、大电流的双片电感器产品线。 IHLD-3232HB-5A 已通过AEC-Q200认证,其工作温度范围达到+155℃,把两颗电感器组合在一个9.75mm x 9.14mm的封装内,能有效节省电路板空间。 今天发布的Vishay Dale电感器适用于汽车和商用的D类放大器电路,减少所需的电路板空间,且性能优于由多个电感器组成的方案。另外,IHLD3232HB
[模拟电子]
MAX98314单声道、3.2W D类放大
 MAX98314单声道、3.2W D类放大器具有AB类放大器的音频性能和D类放大器的效率。该器件通过增益选择输入(GAIN)提供五种增益选择(0dB、3dB、6dB、9dB和12dB)。   限制边沿速率的有源辐射抑制(AEL)、过冲控制电路和无需滤波的扩频调制(SSM)架构大大降低了EMI,省去了传统D类放大器所需的输出滤波器。   IC的低静态电流(3.7V供电时为0.95mA,5.0V供电时为1.2mA)特性,可有效延长便携设备的电池使用寿命。   高线性度、集成输入耦合电容(CIN)减小方案尺寸,与使用外部输入电容的D类放大器相比,能够提供优异的低频音效,提供卓越的THD+N、PSRR和CMRR指标。
[模拟电子]
MAX98314单声道、3.2W <font color='red'>D类放大</font>器
采用扩频调制技术降低D类放大音频应用中的电磁干扰
对D类放大器拓扑结构进行简单的回顾有助于更好地理解电磁干扰(EMI)的根源。D类放大器采用参考的三角波或锯齿波对音频信号进行调制,并产生一个被放大的通常具有脉冲宽度调制(PWM)开关输出形式的信号。虽然调制方式可能有所不同,但所有的D类放大器都以由调制频率所决定的频率(通常远高于音频范围,一般公认在20Hz~20kHz范围内),连续地进行开关操作,输出满摆幅信号,因此必须控制方波载波的占空比,使其平均值与输入信号的瞬时值成正比。典型的开关频率大于输入信号中感兴趣的最高频率的10倍。在大多数D类放大器中,还会使用一条带有误差信号的反馈路径,来提高总谐波失真和噪声(THD+N)性能、电源抑制比(PSRR)和其它一些性能特性。
[模拟电子]
小广播
最新模拟电子文章
