Fairchild FSEZ1317NY 6W LED照明驱动解决方案
最新更新时间:2011-12-01来源: 中电网关键字:LED  照明驱动 手机看文章 扫描二维码
随时随地手机看文章
Fairchild公司的FSEZ1317NY是第三代初级边调整(PSR)和高度集成PWM控制器,待机功耗低于300mW,高压起动,具有最少的外接元件,没有次级反馈电路的恒压(CV)和恒流(CC)控制,PWM固定频率50kHz,主要用在手机,无绳电话,PDA,数码相机等充电器,替代线性变压器和RCC开关电源(SMPS).本文介绍了FSEZ1317主要特性, 功能方框图, 简化PSR反激转换器电路图, 高压起动电路图和6W LED照明驱动器主要特性,电路图和变压器电路图.
FSEZ1317: Primary-Side-Regulation PWM with POWER MOSFET Integrated
This third-generation Primary-Side-Regulation (PSR) and highly integrated PWM controller provides several features to enhance the performance of low-power flyback converters. The proprietary topology, TRUECURRENT™, of FSEZ1317 enables precise CC regulation and simplified circuit design for batterycharger applications. A low-cost, smaller, and lighter charger results, as compared to a conventional design or a linear transformer.
To minimize standby power consumption, the proprietary green mode provides off-time modulation to linearly decrease PWM frequency under light-load conditions. Green mode assists the power supply in meeting power conservation requirements.
By using the FSEZ1317, a charger can be implemented with few external components and minimized cost.
FSEZ1317主要特性:
 Low Standby Power Under 30mW
 High-Voltage Startup
 Fewest External Component Counts
Constant-Voltage (CV) and Constant-Current (CC) Control without Secondary-Feedback Circuitry
 Green-Mode: Linearly Decreasing PWM Frequency
 Fixed PWM Frequency at 50kHz with Frequency Hopping to Solve EMI Problem
 Cable Compensation in CV Mode
 Peak-Current-Mode Control in CV Mode
 Cycle-by-Cycle Current Limiting
 VDD Over-Voltage Protection with Auto Restart
 VDD Under-Voltage Lockout (UVLO)
 Gate Output Maximum Voltage Clamped at 15V
 Fixed Over-Temperature Protection with Auto Restart
 Available in the 7-Lead SOP and DIP Packages
FSEZ1317应用:
 Battery chargers for cELlular phones, cordless phones, PDA, digital cameras, power tools, etc.
 Replaces linear transformers and RCC SMPS
图1. FSEZ1317功能方框图
图2. FSEZ1317简化PSR反激转换器电路图
图3. FSEZ1317高压起动电路图
图4. FSEZ1317典型应用电路图
6W LED照明驱动器
The following reference design supports inclusion of FSEZ1317NY in design of LED illumination.
6W LED照明驱动器主要特性:
Constant-Voltage (CV) and Constant-Current (CC) Control without Secondary- Feedback Circuitry
Built in 700V/1A MOSFET
Low EMI through Frequency Hopping
Low Power Consumption in Standby
Protection Functions: UVLO, Over-Voltage, Over-Current, and Over-Temperature
图5. 6W LED照明驱动器电路图
图6. 6W LED照明驱动器变压器电路图
关键字:LED  照明驱动 编辑:探路者 引用地址:Fairchild FSEZ1317NY 6W LED照明驱动解决方案
上一篇:ST STEVAL-ILL013V1 80W离线LED驱动方案
下一篇:LED驱动电源详解
推荐阅读最新更新时间:2023-10-18 16:10
LED灯具的颜色控制 如何达成?
近年来,固态 LED 照明 灯具大量普及,笔者在此尝试解析LED颜色技术的复杂性及其控制方式。   关于加法混色    LED灯 具采用多个光源获得各种色光和强度。对于演艺灯具行业,加法混色已是老生常谈了。多年来,从业者采用带滤色片的灯具来投射天幕上的同一区域,这种方式控制起来并不容易。笔者使用的首台智能型灯具是一台采用3个MR16光源的聚光灯,它们分别带有红色、绿色和蓝色滤色片。早期,这类灯具只有3个DMX512控制通道,没有独立的强度控制通道。所以很难在调光过程中保持颜色不变。通常,电脑灯程序员还会设置一个“灭光换色”,以便轻易地熄灭灯具。当然,还有更好的方法,此处不再一一列举。   颜色的控制与定义   如
[电源管理]
<font color='red'>LED</font>灯具的颜色控制 如何达成?
LED显示屏关键指标图解说明
1) 物理指标 像素中心距pixEL pitch(点间距) 相邻像素中心之间的距离。(单位:mm) 密度density (点数)   单位面积上像素点的数量(单位:点/m2)。点数同点间距存在一定计算关系 计算公式是:密度=(1000÷像素中心距) led-display.cnLEDw.com/" LED显示屏 的密度越高,图像越清晰,最佳观看距离范围越小。 最佳视距 密度(点/m2) 点间距(mm) 最佳视距(米)     最近 最远 44100
[电源管理]
<font color='red'>LED</font>显示屏关键指标图解说明
传三星Micro LED电视明年CES亮相
电子网消息,苹果积极布局Micro LED屏幕、日前还传出正在跟台积电解决瓶颈问题,而三星也不落人后,传出打算在明 年1月的美国拉斯韦加斯消费性电子展(CES)上,发表一款Micro LED电视。 ZDNet 24日报导 ,三星的Micro LED电视,屏幕将达到150英寸,会在明年稍晚正式上市,瞄准的是家庭剧院市场。 想要制造缩小版的LED,难度相当高。 Micro LED屏幕使用的LED,尺寸不到100微米,每颗LED芯片可做为一个画素,优点是耗电量低,也不会有OLED的残影(burn-in)问题。 若采用塑料制基板,则会具有可挠性。 智能手机需要更加微小的LED芯片,因此应用上还得再等一阵子。 三星发言人不愿对此做出评论。
[手机便携]
led灯倡导节能减排 灯泡寿命可达10年
    第十届高交会展馆一号馆内,一只寿命可达10年左右(5~10万小时)的LED“灯泡”,吸引了许多参观市民的眼球。而湛蓝色的金积嘉电子公司展位里,“再造绿色新三峡——金积嘉LED照明”的字幕则显得分外耀眼。     据介绍,LED照明灯具有节能、减排、环保与寿命长四大优点。一只30瓦的LED半导体晶体“灯泡”,亮度可比120瓦的传统灯具,一只LED“灯泡”可存活5~10万小时。金积嘉公司董事长冯水兴表示,倘若国内1/3的白炽灯被半导体灯取代,年可节电1000亿度,相当于节省一个三峡工程的年发电量。     据记者了解,目前,全球LED照明灯单点光源最大功率为5W,而金积嘉公司已独家研发生产出了60W、75WLED系列照明
[电源管理]
手电筒电池的1.5伏升压到LED所需的3.5伏
这里描述的电源把电压从一节手电筒电池的1.5伏提高到LED所需的3.5伏,同时用电源把LED和手电筒电池串联起来。设计这种电路是为了用LED对手电筒进行改进。增压电路在有两节电池的手电筒中将代替的一节电池,LED装置则代替白炽灯(见图1)。 结果是,仅用一节手电筒电池,LED手电筒就可以用很长时间。该设计最大的难点是:当电源只有一端与电池相连而另一端与白炽灯相连时,提高电压。 图2所示的电源电路要靠一个窍门来工作。在LED装置中,有一个与LED相连的二极管,以便当电源吸收电流时,电流也通过该二极管。在这期间,LED是反向偏置的。经过一段很短的时间,电源停止吸收电流而转向供电,这样LED处于正向偏置状态。 “工作部
[电源管理]
手电筒电池的1.5伏升压到<font color='red'>LED</font>所需的3.5伏
解析两款常见LED照明调光控制解决方案
LED 照明以其发光效率高,使用寿命长,亮度控制简单和环保的优势,迅速受到广大用户的欢迎。作为新型的节能光源,LED灯具会逐步地取代传统的白炽灯泡。 LED照明 的不断普及对调光和控制技术提出了越来越高的要求。当前用户主要关心的是,LED灯具必须要使用安全、重量轻、寿命长、不影响用户健康,并可适用于现有的调光设备以及可以承受的价格。   要满足用户的愿望,就要求驱动电源转换效率高、输出电流纹波低、无光耦设计,并且在接入任何调光器,无论是支持或者不支持的型号,都要保证灯具的安全性能。这对LED的驱动电源提出了极大的挑战。越来越多的LED灯具厂商意识到,传统的驱动方式很难同时兼顾到所有的要求,无法大量推广LED灯。数字电源技术突破了
[电源管理]
解析两款常见<font color='red'>LED</font><font color='red'>照明</font>调光控制解决方案
会流出来的灯光 LED灯泡将水与光结合
这款LED灯非常生动有趣,光变成柔软可触碰的形态,其风格具有浓浓的童话气息,看到超越常识的设计不免有些感动,如同LED灯泡伤心溢出的眼泪。由荷兰设计师PiekeBergman设计,很形象地将光与水两者元素特性互通,并成为蕴含其中的设计元素,让你感觉还在缓缓往下流,一不小心就会有灯光从中溢出来。 会流动的光 LED灯泡将水与光结合
[电源管理]
浅析LED车载显示面板传导模型和影响散热效果进行计算校验测试数据和ANSYS软件
随着LED生产工艺的不断发展,车载手机及其他显示需要亮度越来越高,散热也就成了不得不面临的棘手问题。本文首先阐述了温度上升对LED性能的影响,研究影响散热效果的主要因素,并结合车载显示等特点,提出了一种车载显示热学分析等效模型。然后针对目前车载显示主要采用的被动式散热方式,通过对车载模型进行热学测试计算以及ANSYS软件仿真,最后通过对测试模拟结果的系统分析,给出参考结论,为改善当前LED高亮度显示的散热设计提出了指导性意见。 面板行业对我们来说已不再陌生,在生活中随处可见,大到户外显示屏小到手机Pad这样的终端都有,而且随着技术进步车载显示出货量占了更大比例。LED作为新型高效节能光源,进入显示领域已日趋成熟。并且对于高亮度
[嵌入式]
浅析<font color='red'>LED</font>车载显示面板传导模型和影响散热效果进行计算校验测试数据和ANSYS软件
小广播
最新电源管理文章
