LED信号灯驱动器参考设计
最新更新时间:2011-12-24来源: 电子发烧友网关键字:LED  信号灯  驱动器 手机看文章 扫描二维码
随时随地手机看文章
LED信号灯驱动器参考设计
Abstract: This application note presents a reference design for a signal-lamp linear LED driver that consists of six strings of 4 LEDs per string and delivers 350mA per string with a common cathode configuration. Common cathode arrangements require that the current-sense resistors be placed on the high (anode) side, which forces the LED drivers to use a level shifter.
Circuit Description
This application note describes a linear LED driver for six strings of 4 LEDs to be used in a signal lamp. The LED load provides independent access to the anodes of each string, but the cathodes are common connected. The circuit operates from an automotive battery with a minimum voltage of 10V and a maximum of 28V, while delivering 350mA to each string.
Because of the common cathode configuration, the current-sense resistors must be located on the anode side of the LED strings. Since the LED driver's (MAX16836) current-sense inputs are limited to 4V of common-mode voltage, the voltage across the sense resistors must be level shifted and ground referenced to be compatible with the drivers. The PNP transistor pairs translate the voltage across the LED current-sense resistor to a GND-referenced voltage that is fed into the current-sense pin of the MAX16836. The following equations provide the values for R1, R2, R3, and R4 (in the U1 section of the schematic):
Equations 1 and 2.
Where VSENSE is the current-sense voltage of the IC (200mV).
When the LED string is at its minimum voltage (7.6V) and the input is at its maximum (28V), the LED drivers experience losses of over 7W. Dissipating this heat is almost impossible with circuit board heatsinking methods, so at high voltages a dimming signal with reduced duty cycles (down to 25%) drives the UNIVERSAL DIM input to lessen the power dissipation in the drivers.
This reference design allows for independent enables that allow each string to be controlled separately.
Figure 1 presents a schematic for the circuit, and Table 1 provides the Bill of Materials (BOM). The following are the electrical input requirements and output capabilities.
VIN: 11V to 28V
PWMIN: 10% to 100%
VLED configuration: 7.6VDC (min) to 10VDC (max), 350mA
Figure 1. Schematic of the driver design.
More detailed image (PDF, 7.96kB)
Table 1. Bill of Materials
Designator Component Description Footprint Quantity
C1, C2, C3, C4, C5, C6 Nonpolarized capacitor 0.1µF, 25V 0603 6
C10, C11, C12, C13, C14, C15 Nonpolarized capacitor 0.1µF, 50V 0603 6
Q1, Q2, Q3, Q4, Q5, Q6 Dual PNP transistor DMMT5401 6-SOT23 6
R1, R5, R9, R13, R17, R21 Resistor 0.5Ω 0603 6
R2, R6, R10, R14, R18, R22 Resistor 866Ω 0603 6
R3, R7, R11, R15, R19, R23 Resistor 1.00kΩ 0603 6
R4, R8, R12, R16, R20, R24 Resistor 40.2Ω 0603 6
U1, U2, U3, U4, U5, U6 MAX16836ATE High-brightness LED driver 5mm x 5mm, 16-TQFN with exposed pad 6
关键字:LED  信号灯  驱动器 编辑:探路者 引用地址:LED信号灯驱动器参考设计
上一篇:LED背光boost驱动器
下一篇:LED显示屏如何分类
推荐阅读最新更新时间:2023-10-18 16:16
大功率型LED封装技术
一、引言 半导体 发光二极管简称 LED ,从上世纪六十年代研制出来并逐步走向市场化,其封装技术也是不断改进和发展。LED 由最早用玻璃管封装发展至支架式环氧封装和表面贴装式封装,使得小 功率 LED 获得广泛的应用。从上世纪九十年代开始,由于LED 外延、芯片技术上的突破,四元系AlGaInP 和GaN 基的LED相继问世,实现了LED 全色化,发光 亮度 大大提高,并可组合各种颜色和白光。器件输入功率上有很大提高。目前单芯片1W 大功率LED 已产业化并推向市场,台湾国联也已研制出10W 的单芯片大功率LED。这使得超 高亮度LED 的应用面不断扩大,首先进入特种照明的市场领域,并向普通照明市场迈进。由于LED 芯片
[电源管理]
欧司朗光电半导体进行LED芯片制造升级和产能扩充
二零一一年三月七日 -- 中国讯 - 欧司朗光电半导体在扩大两家芯片制造厂规模的同时,还将它们升级为 6 英寸晶圆制造基地,从而大幅提高产量。其中,马来西亚槟城基地正在兴建一座生产大楼,而德国雷根斯堡基地则正在重新划拨现有厂房。这两个基地都将采用新的制造技术,引入 6 英寸晶圆来替代目前的 4 英寸晶圆。采取这些措施后,到 2012 年底,白光 LED 的芯片产量将有望翻番。 (图片来源:欧司朗) 通过这一系列举措,欧司朗光电半导体将因应国际 LED 市场的增长潜力,趁势扩充雷根斯堡和槟城两个芯片制造基地的产能,进一步夯实其在国际市场的领先地位。槟城芯片制造厂开业不到两年,如今已迎来扩建升级至 6 英
[半导体设计/制造]
LED显示屏灯驱分离与灯驱合一区别分析
   一、灯驱分离   即 LED灯 和 驱动 芯片不在同一块 PCB 板上。实际情况是,焊接LED灯的PCB板与焊接驱动芯片的PCB板通过排阵相连接。考虑到点间距、尺寸、发热等因素,P12一下的模组基本上都采用灯驱分离的方法。从维修的角度来说,灯驱分离的模组比较容易维修。    二、灯驱合一   即LED灯和驱动芯片焊接在同一块PCB板上。因而其优点之一就是可以大大减少PCB板的使用。其缺点也非常明显,灯驱合一所产生的热问题至今尚未能很好的解决,维修也不方便。通常在P16以上的模组会采用这样的方式,但是目前应用不是很理想。所以目前灯驱合一并不是什么先进的概念。    三、室内屏无灯驱合一概念   需要指出的是,室内屏很少会
[电源管理]
Atmel MSL2166 16路白光和RGB LED驱动解决方案
AtmEL公司的MSL2164/MSL2166是小型大功率LED串驱动器,每串电流为350mA,电流匹配优于±0.8%,具有12位PWM串调光,正向,中心,反向和逆向PWM模式,快速20MHz SPI支持多达8个器件/总线,8位自适应功率修正最大化效率,主要用在电视和台式监视器,医疗和工业设备,汽车音/视频显示,建筑物照明等.本文介绍了MSL2164/MSL2166主要特性,方框图和典型应用电路图. 16-string, White and RGB LED Drivers with Adaptive Configuration, EEPROM, and SPI/I2C/SMBus Serial Interface Th
[电源管理]
Atmel MSL2166 16路白光和RGB <font color='red'>LED</font>驱动解决方案
非隔离式电源的共模电流
非隔离式电源的共模电流可能成为一个电磁干扰 (EMI) 源,您是否曾经消除过它呢?在一些高压电源中,例如:LED 灯泡所使用的电源,您可能会发现您无法消除它们。经仔细查看,发现非隔离式电源与隔离式电源其实并没有什么两样。开关节点接地寄生电容,产生共模电流。 图 1 是一个 LED 电源的示意图,其显示了该降压调节器中 共模电流产生的主要原因。原因就是开关节点接地电容。令人惊讶的是,如此小的一点电容,仍会产生问题。CISPR B 类(适用于住宅设备)辐射规定允许 1 MHz 下 46 dBuV (200 uV) 信号的 50 电源阻抗。这也就是说,仅允许 4 uA 的电流。如果转换器在 100 kHz 下对 Q2 漏极的 200
[电源管理]
非隔离式电源的共模电流
LED散热的三大误区
   LED灯具 中,散热的好坏直接关系到产品的质量和寿命。但因为被一些商家的炒作,及所谓的专家的误导,出现了一些误区。   1.迷信导热材料   因为用到什么高科技材料就可以把热散出。其实用普通的铝散热,经多次测试,热沉的温度就只比散热器底部高3-5摄氏度。也就是说,如果真能用到一种导热特好的材料,在热阻为零的情况下,也就可以把温度降低3-5摄氏度。   2.迷信热管   热管有着很好的导热能力,这是毋庸置疑的。但从热沉导出的热最终需要通过空气对流把热带走。如果没有散热的鳍片,热管很快就会达到热平衡,温度同热沉一起上升。而如果在热管上增加散热鳍片,最终还是用鳍片散热。而且鳍片和热管的接触点反而不如其它方式接触好。导致的结果是成本
[电源管理]
led灯珠型号亮度排名_led灯不亮了怎么修
LED英文为(light emit TI ng diode) ,LED灯珠就是发光二极管的英文缩写简称LED。PN结的端电压构成一定势垒,当加正向偏置电压时势垒下降,P区和N区的多数载流子向对方扩散。由于电子迁移率比空穴迁移率大得多,所以会出现大量电子向P区扩散,构成对P区少数载流子的注入。这些电子与价带上的空穴复合,复合时得到的能量以光能的形式释放出去。这就是PN结发光的原理。 LED灯珠特点 1. 电压:LED灯珠使用低压电源,供电电压在 2-4V之间,根据产品不同而异,所以驱动它的是一个比高压电源;更安全的电源,特别适用于公共场所; 2.电流:工作电流在0—15mA,亮度随电流的增大而变亮 3. 效能:消耗能
[电源管理]
广芯电子推出LED背光驱动芯片BCT3220/1
广芯电子(BROADCHIP)推出业内首款能够同时支持共阳极并联LED及共阴极并联LED的背光驱动芯片——BCT3220/BCT3221。 BCT3220/BCT3221: Low Dropout Current Source & Current Sink,功能特点: ·芯片的SEL引脚连接Ground,实现共阳极并联LED驱动功能; ·芯片的SEL引脚连接VIN,实现共阴极并联LED驱动功能; ·每路20mA输出时,Vdropout最低可达50mV; ·8阶数字脉冲控制背光亮度; ·不同通道电流匹配度 2%; ·支持SEL引脚输入PWM,通过PWM
[电源管理]
广芯电子推出<font color='red'>LED</font>背光驱动芯片BCT3220/1
小广播
最新电源管理文章
换一换 更多 相关热搜器件
