2012-03-27OnSemiNCL30051输入90-265Vac60W离线LED驱动方案
最新更新时间:2012-03-27来源: 电子发烧友关键字:AC/DC转换器  开关电源  PFC 手机看文章 扫描二维码
随时随地手机看文章
    On Semi 公司的NCL30051是用于离线LED照明解决方案的PFC和半桥谐振组合控制器,集成了实现高效率和小型LED驱动器/电源所需的所有功能,包括临界导通模式(CrM) PFC升压控制器和内置的600V驱动器的半桥谐振控制器,主要用于高效LED驱动器和电源,电控制齿轮以及照明镇流器.本文介绍了NCL30051主要特性,方框图,典型应用电路以及60W评估板NCL30051LEDGEVB指标,电路图和材料清单(BOM).
    NCL30051LEDGEVB:60W 90-265 Vac 35-50 V Constant Current up to 1.5A Isolated LED Driver
    The NCL30051 is a combination of PFC and half−bridge resonant controllers optimized for off−line LED lighting solutions. This device integrates all the features needed to implement a highly efficient and small form factor LED Driver/Power Supply. It contains a critical conduction mode (CrM) power factor correction (PFC) boost controller and a half−bridge resonant controller with a built−in 600 V driver. The half−bridge stage operates at a fixed frequency, greatly simplifying the control implementations. The output (current or voltage) regulation is achieved by adjusting the PFC stage output voltage − based on a control signal generated external to the NCL30051.
    This device includes an enable input on the PFC feedback pin, open feedback loop protection and PFC overvoltage and undervoltage detectors. Other features included in the NCL30051 are a 600 V startup circuit and an adjustable frequency oscillator with a divide by 2 circuit to assure true symmetric duty ratio. The controllers are properly sequenced, simplifying system design.
    NCL30051主要特性:
Voltage Mode CrM Power Factor Correction Controller
PFC Open Feedback Loop Protection
PFC Undervoltage Detector
PFC Overvoltage Detector
Half−Bridge Stage with 600 V High Side Gate Drive
State Machine Ensures Proper Turn−on and Turn−off of Half−Bridge Stage
Controllers are Properly Sequenced for Fault Free Operation
Non−Latching Fault Management
Internal 600 V Startup Circuit
Wide Temperature Range of −40C to +125C
This is a Pb−Free Device
    NCL30051典型应用:
High Efficiency LED Drivers and Power Supplies
Electronic Control Gear
Lighting Ballasts
图1.NCL30051功能方框图
图2.NCL30051简化应用方框图
This is a fully isolated up to 60 W, 90-265 Vac off-line, power factor corrected, constant current LED driver using ON Semiconductor’s new NCL30051 two-stage controller. This controller contains the control circuitry for both a critical conduction mode (CRM) boost power factor corrector (PFC), and a fixed frequency, series resonant half-bridge converter, and is housed in a 16 pin SOIC package. The driver is designed to support strings of LEDs that have a forward voltage ranging from 35-50 V and has a nominal driver current of 1000 mA although the current can be increased to 1500 mA with simple component changes on the board. This specific driver design is tailored to support LEDs such as the Cree XLAMP™ XP-G and XM-L, and OSRAM Golden DRAGON™ Plus that have maximum drive currents of at least 1000 mA. This board has supports a range of flexible dimming options including bi-level, PWM and analog dimming. Details of the demo board are described in evaluation board manual EVBUM2039/D.
图3.60W NCL30051LEDGEVB评估板外形图
评估板NCL30051LEDGEVB指标:
Universal Input: 90 − 265 Vac (up to 305 Vac with component changes)
Frequency 47 − 63 Hz
Power Factor: > 0.9 (50−100% of Load with dimming)
Harmonic Content EN61000−3−2 Class C Compliance
Efficiency > 88% at 50 −100% of 50 W, Iout = 1 A / Vf = 50 V
Target UL1310 Class 2 Dry/Damp, isolated < 100 VA and < 60 V peak
Vmax Range: 35 to 50 Vdc (selectable by resistor divider)
Constant Current
Iout Range: 0.7 − 1.5 A, 1 A nominal (selectable by resistor)
Vout Compliance >50 to 100% of Vout
Current Tolerance 2% or better
Cold Startup < 1 sec typical to 50% of load
Pout Maximum: 60 W
Dimming: Two Step Bi−level Analog Dimming
PWM dimming with optional DIM board
PWM dimming frequency 160 Hz –300 Hz with external signal input (referenced to a secondary side signal ground)
Dimming range > 10:1
0−10 V (100K) analog voltage input dimming, 1 = minimum, 10 V is 100%
on (range dependent on nominal AC input)
Protection: Short Circuit Protection
Open Circuit Protection < 60 V peak
Over Temperature – (optional)
Over Current Protection − Auto recovery
Over voltage protection (input and optional output)
图4.NCL30051LEDGEVB评估板初级边电路图
图5.NCL30051LEDGEVB评估板次级边电路图
图6.DIM卡电路图
NCL30051LEDGEVB评估板材料清单(BOM):
详清请见:
http://www.onsemi.cn/pub_link/Collateral/NCL30051-D.PDF
http://www.onsemi.cn/pub_link/Collateral/EVBUM2039-D.PDF
关键字:AC/DC转换器  开关电源  PFC 编辑:探路者 引用地址:2012-03-27OnSemiNCL30051输入90-265Vac60W离线LED驱动方案
上一篇:深度聚焦:LED灯难以进入家庭的几个难点
下一篇:LED元件Duris P 5 树立使用寿命与耐腐蚀稳定性新标杆
推荐阅读最新更新时间:2023-10-18 16:34
基于UCC28600准谐振反激式开关电源的方案
  本文提出了一种基于UCC28600控制器的准谐振反激式开关 电源 的设计方案,该方案分析了准谐振反激式开关电源的工作原理及实现方式,给出了电路及参数设计和选择过程,以及实际工作开关波形。实验证明,该方案中所设计的准谐振反激式开关电源具有输入电压范围宽、转换效率高、低EMI、工作稳定可靠的特点。准谐振技术降低了MOSFET的开关损耗,提高产品可靠性。   引言   准谐振转换是十分成熟的技术,广泛用于消费产品的电源设计中。新型的绿色电源系列控制器实现低至150mW的典型超低待机功耗。本文将阐述准谐振反激式转换器是如何提高电源效率以及如何用UCC28600设计准谐振电源。   常规的硬开关反激电路   图1所示为常规的硬开关反激式
[电源管理]
基于UCC28600准谐振反激式<font color='red'>开关电源</font>的方案
开关电源电磁干扰抑制方法浅析
 1 引言   高新技术的不断发展,电子设备的大量使用,电源作为供电部分也越来越受到人们重视。开关电源于其体积小、重量轻、效率高等特点,正逐步取代线性电源,成为电源的主流,但是,其缺点——高频工作条件下产生电磁干扰(Electromagnetic Interference,EMI)——成为不容忽视的问题,阻碍了电源的发展。   EMI 信号占有很宽的频率范围,又有一定的幅度,经过在电路、空间中的传导和辐射,污染了周围的电磁环境,影响了与其它电子设备的电磁兼容(Electromagnetic Compatibility,EMC)性。本文就电磁干扰的产生机理进行简单的介绍,重点总结了几种近年来提出的抑制开关电源电磁干扰产生及传播
[电源管理]
<font color='red'>开关电源</font>电磁干扰抑制方法浅析
触发管在高压开关电源保护电路中的应用
1 引言 触发管是利用管内气体介质在外加电场的作用下产生放电而实现各种不同应用目的的器件。根据管内气体压力的不同可分为充气触发管和真空触发管两类,其工作机理基本相同。触发管大多作为脉冲功率装置中大功率通断开关以及过电压与过电流保护的通断开关。最典型的应用是行波管保护电路。 触发管因其快速反应能力,不但能用于保护行波管这一类特性不稳定的负载,还可用于保护高压开关电源本身,解决了开关电源由于反馈控制延时带来的过压保护问题。 2 触发管的结构及工作原理 以冷阴极触发管为例来介绍触发管的基本工作原理。典型冷阴极触发管是一种陶瓷金属(或玻璃金属)封装的三电极充气开关器件,能在短时间内控制导通一定的电流能量。 图1示出
[电源管理]
触发管在高压<font color='red'>开关电源</font>保护电路中的应用
满足新应用需求的先进PFC技术及解决方案
            功率因数校正(PFC)是电源设计人员面临的重要任务。根据IEC61000-3-2谐波标准中的D类规定,功率在75 W以上的个人计算机和电视机等电子系统的电源要进行功率因数校正。       根据输入电流控制原理的不同,PFC可以分为不同的类型,如临界导电模式(CrM)、不连续导电模式(DCM)、连续导电模式(CCM)和频率钳位临界导电模式(FCCrM)等。CrM的的主要特征是电流有效值(RMS)大,开关频率不固定,常用于需要简单控制方案的照明和交流适配器等低功率应用,典型解决方案如安森美半导体NCP1606;DCM的主要特征是电流有效值最高,线圈电感较低及稳定性最佳,常见于中低功率应用;CCM的主
[电源管理]
高频开关电源的组成及分类
高频开关电源的组成与分类 开关电源 具有体积小、效率高等一系列优点,在各类电子产品中得到广泛的应用。但由于开关电源的控制电路比较复杂、输出纹波电压较高,所以开关电源的应用也受到一定的限制。 电子装置小型轻量化的关键是供电电源的小型化,因此需要尽可能地降低电源电路中的损耗。开关电源中的调整管工作于开关状态,必然存在开关损耗,而且损耗的大小随开关频率的提高而增加。另一方面,开关电源中的变压器、电抗器等磁性元件及电容元件的损耗,也随频率的提高而增加。 目前市场上开关电源中功率管多采用双极型晶体管,开关频率可达几十kHz;采用MOSFET的开关电源转换频率可达几百kHz。为提高开关频率必须采用高速开关器件。对于兆赫以上开关频率
[电源管理]
高频<font color='red'>开关电源</font>的组成及分类
一种适合教学的开关电源设计及调试
线性稳压电路具有结构简单,调整方便,输出电压脉动小的优点,但缺点是效率低,一般只有20%~40%,并且比较笨重。开关型稳压电路能克服线性稳压电源的缺点,具有效率高,一般能达到65%~90%,并且体积小,重量轻,对电网电压要求不高,因而在实际生活中得到广泛应用。也正因为其应用的广泛性,相应专业的学生就更应该深刻和熟练地掌握它,在此以设计脉冲宽度调制型开关电路(PWM)为基础,详细解说该系统的调试过程。 1 系统设计原理 PWM型的开关电源整体框图如图1所示。变压、整流、滤波模块处理起来比较简单,只要采用相应的变压器、单相全波整流、电容式滤波即可实现,这里不用更多的篇幅介绍。此系统的核心模块是方框图中的闭合(负反馈)模块。如果直接采
[电源管理]
一种适合教学的<font color='red'>开关电源</font>设计及调试
开关电源中高频磁性元件设计常见错误概念
1 引言   开关电源中高频磁性元件的设计对于电路的正常工作和各项性能指标的实现非常关键.加之高频磁性元件设计包括很多细节知识点,而这些细节内容很难被一本或几本所谓的“ 设计大全 ” 一一罗列清楚 .为了优化设计高频磁性元件,必须根据应用场合,综合考虑多个设计变量,反复计算调整.正由于此,高频磁性元件设计一直是令初涉电源领域的设计人员头疼的难题,乃至是困扰有多年工作经验的电源工程师的问题.   很多文献及相关技术资料给出的磁性元件设计方法或公式往往直接忽略了某些设计变量的影响,作了假设简化后得出一套公式;或者并未交代清楚公式的应用条件,甚至有些文献所传达的信息本身就不正确.很多电源设计者并没有意识到这一点,直接套用设计手册中的
[电源管理]
开关电源直流EMI滤波器的设计及实现
摘要:介绍了基于二端口网络理论的开关电源直流EMI滤波器设计的一般原理和方法。该原理适合于任何滤波器的设计,在实际应用中取得了良好的滤波效果。 关键词:EMI滤波器;输入导纳;输出阻抗 引言 电子技术的迅速发展,对电子仪器和设备提出了更高的要求:性能上,更加安全可靠;功能上,不断增加;使用上,自动化程度越来越高;体积上,要日趋小型化。这使得具有众多优点的开关电源在计算机、通信、航天、彩色电视等方面得到了日益广泛的应用。但是,在开关稳压电源中,开关管工作在开关状态,其交变电压和电流会通过电路的元器件产生很强的尖峰干扰和谐振干扰。这些干扰严重地污染了市电电网,影响了邻近电子仪器及设备的正常工作;同时,由于这一缺点,使得开关电源
[电源管理]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
