FairchildFAN6920MR临界模式PFC电源解决方案
最新更新时间:2011-08-23来源: chinaaet关键字:电源管理  AC/DC转换器  开关电源  PFC 手机看文章 扫描二维码
随时随地手机看文章
Fairchild公司的FAN6920MR是采用mWSaver技术的集成了临界模式PFC控制器和准谐振电流模式PWM控制器,提供了成本效益的设计和降低了外接元件. FAN6920MR具有谷低检测,绿色模式工作以及高/低火线电压超功率补偿,从而提高了电源系统的性能,主要用在笔记本电脑适配器,开架开关电源和电池充电器.本文介绍了FAN6920MR主要特性,方框图, 典型应用电路图, 设计案例最终电路图,材料清单和PCB布局考虑.
FAN6920MR: mWSaver™ Technology Integrated Critical-Mode PFC and Quasi-Resonant Current-Mode PWM Controller
Factor Correction (PFC) controller and quasi-resonant PWM controller. Integration provides cost-effective design and reduces external components.
For PFC, FAN6920MR uses a controlled on-time technique to provide a regulated DC output voltage and to perform natural power-factor correction. With an innovative THD optimizer, FAN6920MR can reduce input current distortion at zero-crossing duration to
improve THD performance.
For PWM, FAN6920MR provides several functions to enhance the power system performance: valley detection, green-mode operation, and high / low line over-power compensation. Protection functions include secondary-side open-loop and over-current with autorecovery protection; external auto-recovery triggering; adjustable over-temperature protection by RT pin; and external NTC resistor, internal over-temperature shutdown, VDD pin OVP, and DET pin over-voltage for output OVP, and brown-in / out for AC input voltage UVP.
The FAN6920MR controller is available in a 16-pin small-outline package (SOP).
FAN6920MR主要特性:
 Integrated PFC and Flyback Controller
 Critical-Mode PFC Controller
 Zero-Current Detection for PFC Stage
 Quasi-Resonant Operation for PWM Stage
 Internal Minimum 5μs tOFF for QR PWM Stage
 Internal 5ms Soft-Start for PWM
 Brownout Protection
 High / Low Line Over-Power Compensation
 Auto-Recovery Over-Current Protection
 Auto-Recovery Open-Loop Protection
 Externally Auto-Recovery Triggering (RT Pin)
 Adjustable Over-Temperature Protection
 VDD Pin and Output Voltage OVP (Auto-Recovery)
 Internal Over-Temperature Shutdown (140°C)
FAN6920MR应用:
 AC/DC NB Adapters
 Open-Frame SMPS
 Battery Charger
图1.FAN6920MR方框图
图2.FAN6920MR典型应用电路图
图3.FAN6920MR设计案例最终电路图
图4. 设计案例布局考虑
设计案例材料清单:
关键字:电源管理  AC/DC转换器  开关电源  PFC 编辑:探路者 引用地址:FairchildFAN6920MR临界模式PFC电源解决方案
上一篇:电平位移电路应用于负电源的设计
下一篇:照明电源中电容作用详解
推荐阅读最新更新时间:2023-10-18 15:36
PLL的电源管理设计
锁相环(PLL)是现代通信系统的基本构建模块PLLs通常用在无线电接收机或发射机中,主要提供 本振 (LO)功能;也可用于时钟信号分配和降噪,而且越来越多地用作高采样速率模数或 数模转换的时钟源。由于每一代PLL的噪声性能都在改善,因此电源噪声的影响变得越来越明显,某些情况下甚至可限制噪声性能。本文讨论图1所示的基本PLL方案,并考察每个构建模块的电源管理要求。 图1.显示各种电源管理要求的基本锁相环 PLL中,反馈控制环路驱动电压控制振荡器(VCO),使振荡器频率(或相位)精确跟踪所施加基准频率的倍数。许多优秀的参考文献 解释了PLL的数学分析;ADI的ADIsimPLL 等仿真工具则对了解环路
[电源管理]
PLL的<font color='red'>电源管理</font>设计
开关电源接假负载,并不是想接就能接的!
开关电源在负载短路时会造成输出电压降低,同样在负载开路或空载时输出电压会升高。在检修中一般采用假负载取代法,以区分是电源部分有故障还是负载电路有故障。关于假负载的选取,一般选取40W或60W的灯泡作假负载(大屏幕彩色电视机可选用100W以上的灯泡作假负载),优点是直观方便,根据灯泡是否发光和发光的亮度可知电源是否有电压输出及输出电压的高低。但缺点也是显而易见的,例如60W的灯泡其热态电阻为500Q,而冷态电阻却只有50Ω左右。根据下表可以看出:假设电源主电压输出为100V,当用60W灯泡作假负载时,电源工作时的电流为200mA,但启动时的主负载电流却达到了2A,是正常工作电流的10倍,因此,用灯泡作假负载,易使电源启动困难,由于灯
[电源管理]
开关电源拓扑结构详解
主回路—开关电源中,功率电流流经的通路。主回路一般包含了开关电源中的开关器件、储能器件、脉冲变压器、滤波器、输出整流器、等所有功率器件,以及供电输入端和负载端。   开关电源(直流变换器)的类型很多,在研究开发或者维修电源系统时,全面了解开关电源主回路的各种基本类型,以及工作原理,具有极其重要的意义。   开关电源主回路可以分为隔离式与非隔离式两大类型。   1. 非隔离式电路的类型:   非隔离——输入端与输出端电气相通,没有隔离。   1.1. 串联式结构   串联——在主回路中开关器件(下图中所示的开关三极管T)与输入端、输出端、电感器L、负载RL四者成串联连接的关系。   开关管T交替工作于通/
[电源管理]
<font color='red'>开关电源</font>拓扑结构详解
复杂的移动终端产品系统级电源管理设计方法
  引言:要想继续保持较长的电池寿命,就必须改善设备的电源管理设计,更加注重如何将多种必要的电源管理功能集成到一项技术中,同时又不牺牲技术性能。基于Smart Mirror专有架构的电源管理子系统IC就实现了一种系统级电源管理方法。   电池技术的进步以及业界对具有低工作电压的多电源域的需求正在对便携式电子设备的电源管理系统设计提出一些新的要求。   图1:DA9025电源管理芯片。   在为手机、便携式媒体播放器等电子设备中增加新功能时,要想继续保持消费者已经习惯的待机时间长度,就必须改善设备的电源管理设计。随着多媒体音频、视频和游戏功能的日益普及,不可避免地导致系统电池消耗增大。用户并不会注意到这些影响,
[电源管理]
复杂的移动终端产品系统级<font color='red'>电源管理</font>设计方法
电源生产厂家详解开关电源制造流程四部曲(有图)
第一、产前对BOM: 对于新订单,工程部门必须依标准对电源进行老化 测试 ,再由品质部门做最终可靠性老化、可靠性 测试 ,品质确认OK再对产品及PCB板进行拍照存档,并在可靠性测试报表签名,工程工程负责人依可靠性报表及照片作这依据才能在BOM签字,再由工程部主管签字方可生效。样品再由制造工程分晰其生产加工的合理性,并在作业指导书上签字,方可生产。对于ERP已存在的BOM两个月内没有生产的机型由工程部再次确认,方可生产,两月内生产的机型可以直接生产,每次生产前工程必须提供两个以上的手件样品及 PCB 组立。 第二、生产部贴片插件: 贴片插件前必须有工程提供的原始PCB样板,在贴片插件前必须按PCB组立的样品贴片插件,再贴片插件
[电源管理]
电源生产厂家详解<font color='red'>开关电源</font>制造流程四部曲(有图)
欧胜针对便携应用推出高电流单片电源管理芯片
      欧胜微电子股份有限公司今日宣布推出极富创新的WM8325电源管理子系统,该子系统是世界上最高电流的单片电源管理芯片(PMIC),它为包括智能本、平板电脑、电子书、媒体播放器以及智能手机在内的各种便携式多媒体应用提供了一种高性价比、灵活的解决方案.       WM8325的特点是带有4个可编程的直流-直流转换器,其中包含一个可以提供高达2.5A的转换器;它同时还集成了11个低压差线性稳压器(LDO),其中的4个用于以低噪音方式为灵敏的模拟子系统供电。其经过优化的QFN封装是为了改进热性能和减少寄生元件,同时确保能够采用低成本的4层印制电路板(PCB)来制造。这种封装允许在所有高电流路径上采用大型的PCB线径,
[电源管理]
欧胜针对便携应用推出高电流单片<font color='red'>电源管理</font>芯片
反激开关电源输出电容计算
1、 设定开关工作频率:f=60kHz,输出电流Io=1A;根据变压器,输入、输出电压求实际最大占空比Dmax=0.457; 2、 计算Toff、Ton: Toff=1/f*(1-Dmax)=9.05 Ton=1/f*Dmax=7.62 3、 计算输出峰值电流: 4、 根据反激式输出波形,来计算输出电容量: 由上图波形可知:Io减少、Uo也减小,即输出电解电容主要维持t1到t2时间段电压。设输出纹波为120mV则: 5、 纹波电流,一般取输出电流的5%~20%,即Inppl=20%*1=0.2A实际每个电解电容的纹波电流为0.2A,故满足设计要求。
[电源管理]
反激<font color='red'>开关电源</font>输出电容计算
FA5310/FA5311开关电源控制IC及其应用
    摘要: FA5310/FA5311是日本富士电机公司推出的新型开电源控制IC,它具有多种保护功能,且外接电路简单,应用方便。文中介绍了FA5310/FA5311开关电源控制IC的性能、特点及工作原理。并给出了它的一种具体应用电路。      关键词: FA5310  FA5311  开关电源  场效应管 1 概述     许多电子系统都需要开关电源,开关电源的电路多种多样,现在已有许多控制芯片得到应用。控制芯片的广泛应用大大简化了电路设计,它们只要再外接一些器件即可组成开关电源。FA5310/FA5311是日本富士电机公司的产品,它具有多种保护功能,外接电路简单,具有很大
[电源管理]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
