The NCV8855 is a multiple output controller / regulator IC with an integrated high−side load switch. The NCV8855 addresses automotive radio system and instrument cluster power supply requirements. In addition to the high−side load switch, the NCV8855 includes a switch−mode power supply (SMPS) buck controller, a 2.5 A SMPS buck regulator and two low dropout (LDO) linear regulator controllers. The NCV8855 in combination with the ultra−low quiescent current NCV861x IC forms an eight−output automotive radio or instrument cluster power solution. The NCV8855 has an internally set switching frequency of 170 kHz, with a SYNC pin for external frequency synchronization.
The NCV8855 is intended to supply power to various loads, such as a tuner, CD logic, audio processor and CD / tape control within a car radio. The high−side switch can be used for a CD / tape mechanism or switching an electrically−powered antenna or display unit. In an instrument cluster application, the NCV8855 can be used to power graphics display, flash memory and CAN transceivers. In addition, the high−side switch can be used to limit power to a TFT display during a battery over−voltage condition.
NCV8855主要特性:
• < 1 uA Shutdown Current
• Meets ES−XW7T−1A278−AB Test Pulse G – Loaded Conditions
• VIN Operating Range 9.0 to 18.0 V
• 1 SMPS Controller with Adjustable Current Limit
• 1 SMPS Regulator with Internal 300 m NMOS Switch
• 2 LDO Controllers with Current Limit and Short Circuit Protection
• 1 High−side Load Switch with Internal 300 m NMOS FET
• Adjustable Output Voltage for All Controllers / Regulators
• 800 mV, +/-1% Reference Voltage
• System Enable Pin
• Single Enable Pin for Both LDO Controllers
• Independent Enable for High−side Load Switch
• Thermal Shutdown with Thermal Warning Indicator
• This is a Pb−Free Device
NCV8855应用:
• Automotive Radio
• Instrument Cluster, Driver Information System (DIS)
图1. NCV8855应用电路/方框图
图2. NCV8855和NCV8612汽车无线电系统框图
NCV8855评估板
图3.评估板NCV8855BMNR2GEV外形图
图4.评估板NCV8855BMNR2GEV电路图
评估板NCV8855BMNR2GEV材料清单:
详情请见:
http://www.onsemi.cn/pub_link/Collateral/EVBUM2120-D.PDF
和
http://www.onsemi.cn/pub_link/Collateral/NCV8855BMNR2GEVB_SCHEMATIC.PDF
上一篇:开关电源技术的发展
下一篇:一款实用高性能开关电源的设计与实现
推荐阅读最新更新时间:2023-10-17 15:00
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- NXP 2.5亿美元收购Aviva,但车载SerDes领域依然处于战国时期
- 应对 AI 时代的云工作负载,开发者正加速向 Arm 架构迁移
- 沉浸式体验漫威宇宙,英特尔锐炫显卡为《漫威争锋》提供Day 0支持
- 艾迈斯欧司朗与法雷奥携手革新车辆内饰,打造动态舱内环境
- 《嵌入式-STM32开发指南》第二部分 基础篇 - 第7章DMA(HAL库)
- 【“源”察秋毫系列】DC-DC电源效率测试,确保高效能与可靠性的关键步骤
- NVIDIA 推出高性价比的生成式 AI 超级计算机
- Mapbox与Arm合作推出虚拟主机 加速软件定义汽车导航
- 移植tslib和Qt5.6到三星s5pv210开发板
- 智能座舱新赛点在哪? 看这四款重磅新车
