/* SD Code for M32L */
/* By pasyong */
/* 2006-4 */
/* Base ICC6.31A */
#include
#include
#include "1011.h"
#define uchar unsigned char
#define uint unsigned int
#define MMC_CS_PIN BIT(4) //PORTB.4
#define MMC_PORT PORTB
uchar reading=0,a=0,pointer=0;
void sd_port_init()
MMC_PORT|=MMC_CS_PIN;
uchar BUFFER[512]; //扇区缓冲区
uint i=0;
void delay_nus(uint n)
unsigned char b;
for (b = 1; b
//Send a Command to MMC/SD-Card
//Return: the second byte of response register of MMC/SD-Card
uchar SD_Write_Command(uchar cmd,unsigned long arg)
uchar tmp;
uchar retry=0;
//MMC_PORT|=MMC_CS_PIN; //SD卡关闭
//send 8 CLOCk Impulse
Write_Byte_SPI(0xFF);
//set MMC_Chip_Select to low (MMC/SD-Card active)
MMC_PORT&=~MMC_CS_PIN; //SD卡使能
Write_Byte_SPI(cmd|0x40); //送头命令
Write_Byte_SPI(arg>>24);
Write_Byte_SPI(arg>>16); //send 6 Byte Command to MMC/SD-Card
Write_Byte_SPI(arg>>8);
Write_Byte_SPI(arg&0xff);
Write_Byte_SPI(0x95); //仅仅对RESET有效的CRC效验码
//get 8 bit response
//Read_Byte_MMC(); //read the first byte,ignore it.
do
{ //Only last 8 bit is used here.Read it out.
tmp = Read_Byte_SPI();
retry++;
while((tmp==0xff)&&(retry<100)); //当没有收到有效的命令的时候
if(reading==0)
MMC_PORT|=MMC_CS_PIN; //MMC_CS_PIN=1;
else MMC_PORT&=~MMC_CS_PIN; //MMC_CS_PIN=0;
return(tmp);
//SD卡初始化(SPI-MODE)
uchar SD_Init(void)
uchar retry,temp;
uchar i;
delay_nus(250); //Wait MMC/SD ready...
for (i=0;i<0x0f;i++)
Write_Byte_SPI(0xff); //send 74 clock at least!!!
//Send Command CMD0 to MMC/SD Card
retry=0;
do
{ //retry 200 times to send CMD0 command
temp=SD_Write_Command(0,0);
retry++;
if(retry==100)
;//CMD0 Error!
while(temp!=1);
//Send Command CMD1 to MMC/SD-Card
retry=0;
do
{ //retry 100 times to send CMD1 command
temp=SD_Write_Command(1,0);
retry++;
if(retry==100)
while(temp!=0);
retry=0;
SD_Write_Command(16,512); //设置一次读写BLOCK的长度为512个字节
MMC_PORT|=MMC_CS_PIN; //MMC_CS_PIN=1; //set MMC_Chip_Select to high
return(0); //All commands have been taken.
//从SD卡读一个扇区 Return 0 if no Error.
uchar SD_Read_Block(unsigned long address)
uchar temp=0;uint i=0;
reading=1;
temp=SD_Write_Command(17,address); //读出RESPONSE
while (Read_Byte_SPI()!= 0xfe)
{;} //直到读取到了数据的开始头0XFE,才继续
for(i=0; i<512; i++)
BUFFER[i]=Read_Byte_SPI();
Read_Byte_SPI();//CRC - Byte
reading=0;
MMC_PORT|=MMC_CS_PIN; //关闭SD卡
return(temp);
上一篇:DS1302的AVR程序(2000年~2099年的星期自动计算功能)
下一篇:在数码管上显示ADIN0口输入的电压
推荐阅读最新更新时间:2024-03-16 15:49
设计资源 培训 开发板 精华推荐
- [年末调查]工程师年末大盘点,你被点名了!
- 有奖直播|TI MSP430™民用超声波水表开发指南及其智能模拟组合模块在传感器检测中的应用
- 炎炎盛夏,EEWORLD社区6月明星人物出炉喽!
- 泰克MDO系列:1招搞定6大仪器,轻松穿越模拟、数字、频域测量
- Microchip 有奖直播|满足汽车电池管理系统 (BMS) 不断发展的安全标准
- ADI 新一期《模拟对话》上线,免费下载ing!
- 下载泰克高速接口标准电子书,参与翻盖有礼,惊喜多多!
- 【EEWORLD带你DIY】数字示波器V2.0火热进行中......
- 有奖问答:在线寻找英特尔® 视觉加速设计“全知”达人
- 泰克示波器,朝第二个百万台销售纪录前进!
