STM32开发笔记8: STM32CubeF0介绍
发布者:科技舞者最新更新时间:2019-07-17 来源: eefocus关键字:STM32  STM32CubeF0  介绍 手机看文章 扫描二维码
随时随地手机看文章
单片机型号:STM32CubeF0
    本文介绍 STM32CubeF0。
    STM32CubeF0 gathers, in a single package, all the generic embedded software components required to develop an application on STM32F0 microcontrollers. In line with the STMCube™ initiative(首创), this set of components is highly portable, not only within STM32F0 Series but also to other STM32 Series.(大意:STM32CubeF0很不错,不仅应用于F0系列,还可用于其它STM32系列。)
    STM32CubeF0 is fully compatible with STM32CubeMX code generator that allows generating initialization code. The package includes Low Layer (LL) and hardware abstraction layer (HAL) APIs that cover the microcontroller hardware, together with an extensive(广泛的) set of examples running on STMicroelectronics boards. The HAL and LL APIs are available in open-source BSD license for user convenience.(大意:STM32CubeF0完全兼容STM32CubeMX允许产生初始化代码,开发包高阔底层和硬件映象层API覆盖了整个微处理器硬件,并且给出了大量的可在开发板上运行的样例程序,并且开源。)
    STM32CubeF0 package also contains a set of middleware components with the corresponding examples. They come in free user-friendly license terms: (大意:STM32CubeF0开发包包含一系列还有样例程序的中间件,遵循自由协议。)
    • Full USB Device stack supporting many classes: Audio, HID, MSC, CDC and DFU(USB)
    • STemWin, a professional graphical stack solution available in binary format and based on STMicroelectronics partner solution SEGGER emWin(图形用户界面)
    • CMSIS-RTOS implementation with FreeRTOS open source solution(实时操作系统)
    • FAT File system based on open source FatFS solution(文件系统)
    • STMTouch touch sensing library solution.(触摸屏)
    Several applications and demonstrations implementing all these middleware componentsare also provided in the STM32CubeF0 package.(大意:STM32CubeF0开发包提供了大量的使用这些中间件的样例程序。)
    STM32CubeF0固件组件图,如下图所示:
关键字:STM32  STM32CubeF0  介绍 引用地址:STM32开发笔记8: STM32CubeF0介绍
上一篇:STM32开发笔记9: STM32CubeF0固件架构
下一篇:STM32开发笔记7: ST-LINK/V2-1驱动程序的安装
推荐阅读最新更新时间:2024-11-11 06:12
STM32下载显示target dll has been cancelled
使用MDK 4.74向STM32下载时出现各种错误,而且时隐时现, Internal command error.Error:Flash download failed. Target DLL has been cancelled. 最初的解决方法就是让STM32不采用外部供电而是让下载器直接供电,同时将BOOT0上拉(BOOT0上拉使从RAM启动)。这样以上各种问题就顺利解决了。 或者是BOOT0拉低(BOOT0下拉从FLASH启动),点击KEIL的DOWNLOAD前先按下板子上的复位键不放,然后点击DOWNLOAD,点击完毕后迅速抬起复位键(也就是在STM32从FLASH启动初始化完毕前就烧录),之后程序就烧录进去了。
[单片机]
STM32中断系统笔记
CM3中 STM32参考教程: STM32开发指南V1.0库函数版
[单片机]
<font color='red'>STM32</font>中断系统笔记
STM32的串口通信原理介绍
介绍串口通信 按照数据传送方向分类 单工:数据传输只支持数据在一个方向上传输 半双工:允许数据在两个方向上传输。但是,在某一时刻,只允许数据在一个方向上传输,它实际上是一种切换方向的单工通信;它不需要独立的接收端和发送端,两者可以合并一起使用一个端口 全双工:允许数据同时在两个方向上传输。因此,全双工通信是两个单工通信方式的结合,需要独立的接收端和发送端 按照通信方式分类 同步通信:带时钟同步信号传输。比如:SPI,IIC通信接口 异步通信:不带时钟同步信号。比如:UART(通用异步收发器),单总线 在同步通讯中,收发设备上方会使用一根信号线传输信号,在时钟信号的驱动下双方进行协调,同步数据。例如,通讯中通常双方会统一规定在时
[单片机]
STM32 关于外部中断线、中断源和中断服务函数的问题
中断线问题: 上图可以看出,PA0、PB0...PG0共用的EXTI0中断线,PA1、PB1...PG1共用的EXTI1中断线,也就是 编程里面的(如下图库文件),对应16个中断线,后面三个是专用的中断线,不做讨论。 有人要问,假设:我设置的引脚是PB9和PE9都开启外部中断怎么办?小编告诉你,这还真办不了,我实测过。配置函数的时候后覆盖之前的函数的(如下图所示) 如果这样配置的话,会出现出货光电1的初始化覆盖掉编码盘的初始化,说白了就是编码盘的设置被覆盖掉了,结果是外部中断 出货光电1管脚会触发而编码盘就不起作用了,这也是STM32其中一个问题所在吧! 反过来,结果是外部中断 编码盘 管脚会触发 而 出货光电1管脚
[单片机]
<font color='red'>STM32</font> 关于外部中断线、中断源和中断服务函数的问题
STM32 USART串口的应用 STM32中断系统专题讲解
STM32 ,从字面上来理解, ST 是 意法半导体 , M 是 M ic roelectronics 的缩写, 32 表示 32 位,合起来理解, STM32 就是指 ST 公司 开发的 32 位 微控制器 。在如今的 32 位 控制器 当中, STM32 可以说是最璀璨的新星,它受宠若娇,大受 工程师 和市场的青睐,无芯能出其右。 51 是嵌入式学习中一款入门级的精典 MCU ,因其结构简单,易于教学。 51诞生于 70 年代,属于传统的 8 位 单片机 ,如今,久经岁月的洗礼,既有其辉煌又有其不足。现在的市场 产品 竞争越来越激烈,对成本极其敏感,相应地对 MCU 的性能要求也更苛刻:更多功能,更低功耗,易用界面和多任务。面
[单片机]
<font color='red'>STM32</font> USART串口的应用 <font color='red'>STM32</font>中断系统专题讲解
汽车电子e-Mark测试案例介绍之瞬态传导测试
我们在以往的文章中以车载DVD播放器为例介绍了汽车电子的辐射骚扰测试,本期我们将继续以DVD播放器为例谈谈汽车电子EMC测试中的瞬态传导测试。实例分析: 产品名称:车载DVD播放器 产品功能描述:DVD播放功能,FM/AM接收功能,USB Host功能 工作电压:12V DC 认证标准:2004/104/EC(ISO 7637-2) 测试端口:DC电源线 实验等级:Ⅲ测试具体要求: 波形1:模拟了电源从感性负载断开时,与感性负载并联的被测件上所产生的瞬态脉冲 (实验脉冲) (脉冲参数) 脉冲2a 和2b:脉冲2a 模拟由于线束电感的原因,使与DUT 并联的装置内电流突然中断引起的瞬态现象;脉冲2b 模拟直流电机充当发电机
[测试测量]
汽车电子e-Mark测试案例<font color='red'>介绍</font>之瞬态传导测试
stm32常见错误分析
1.warning: #550-D: variable d was set but never used 描述:变量'd'定义但从未使用,或者是,虽然这个变量你使用了,但编译器认为变量d所在的语句没有意义,编译器把它优化了. 解决:仔细衡量所定义的变量d是否有用,若是认定变量d所在语句有意义,那么尝试用volatile关键字修饰变量d,若是真的没有用,那么删除掉以释放可能的内存. 2.warning: #1-D: last line of file ends without a newline 描述:文件最后一行不是新的一行.编译器要求程序文件的最后一行必须是空行,想了半天没想通为什么要这样. 解决:可以不理会.若
[单片机]
掌握这三个思路告诉你如何使用STM32测量频率和占空比
题目 (1)测量脉冲信号频率fo,频率范围为10Hz~2MHz,测量误差的绝对值不大于0.1%。 (2)测量脉冲信号占空比D,测量范围为10%~90%,测量误差的绝对值不大于2%。 使用官方STM32F429 Discovery开发板,主频180MHz,定时器频率90MHz。 思路一、外部中断 这种方法是很容易想到的,而且对几乎所有MCU都适用(连51都可以)。方法也很简单,声明一个计数变量TIM_cnt,每次一个上升沿/下降沿就进入一次中断,对TIM_cnt++,然后定时统计即可。如果需要占空比,那么就另外用一个定时器统计上升沿、下降沿之间的时间即可。 缺陷显而易见,当频率提高,将会频繁进入中断,占用大量时间。而当频
[单片机]
掌握这三个思路告诉你如何使用<font color='red'>STM32</font>测量频率和占空比
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
