本文介绍了LT3575主要特性,方框图以及多种单输出,双输出和四输出隔离转换器电路图。Linear 公司的LT3575是用于隔离反激拓扑的开关电源稳压器,不需要第三个绕组或光隔离器。输入电压3-40V,集成了2.5A/60V NPN功率开关,输出功率可高达14W,主要应用在工业,汽车和医疗设备的隔离电源。
Isolated Flyback Converter without an Opto-Coupler
The LTR3575 is a monolithic switching regulator specifically designed for the isolated flyback topology. No third winding or optoisolator is required for regulation. The part senses the isolated output voltage directly from the primary side flyback waveform. A 2.5A, 60V NPN power switch is integrated along with all control logic into a 16-lead TSSOP package.
The LT3575 operates with input supply voltages from 3V to 40V, and can deliver output power up to 14W with no external power switch. The LT3575 utilizes boundary mode operation to provide a small magnetic solution with improved load regulation.
The output voltage is easily set with two external resistors and the transformer turns ratio. Off the shelf transformers are available for many applications.
LT3575主要特性:
3V to 40V Input Voltage Range
2.5A, 60V Integrated NPN Power Switch
Boundary Mode Operation
No Transformer Third Winding or Optoisolator Required for Regulation
Improved Primary-Side Winding Feedback Load Regulation
VOUT Set with Two External Resistors
BIAS Pin for Internal Bias Supply and Power NPN Driver
Programmable Soft-Start
Programmable Power Switch Current Limit
Thermally Enhanced 16-Lead TSSOP
LT3575应用:
Industrial, Automotive and Medical Isolated Power Supplies
图1。LT3575方框图
图2。LT3575低输入电压5V隔离反激转换器电路图
图3。LT3575 +/-12V隔离反激转换器电路图
图4。LT3575 5V隔离反激转换器电路图
图5。LT3575 3.3V隔离反激转换器电路图
图6。LT3575 12V隔离反激转换器电路图
图7。LT3575 四输出12V隔离反激转换器电路图
关键字:LT3575 隔离反激 电源转换
编辑:神话 引用地址:基于LT3575设计的隔离反激型电源转换技术
LT3575主要特性:
LT3575应用:
图1。LT3575方框图
上一篇:基于MAX16834设计的112W升压LED驱动器技术
下一篇:图解DIY自制夜光LED手电筒
推荐阅读最新更新时间:2023-10-13 10:55
优化电源转换器控制回路的三种方案
Three Options to Optimize the Control Loop of Power Converters 优化电源转换器控制回路的三种方案 问题:选择电源转换器的外部元件有什么简单办法吗? 答案: 有三种方法。 几乎每个电源都有一个控制回路,以确保输出电压为恒定值。电源设计旨在优化控制回路,以便在输入电压或负载瞬变出现波动时,最大限度地减少控制输出电压与设定值之间的偏差。这里的一个重要关系是输出电容的大小与开关稳压器IC的响应速度的关系。如果回路响应特别快,则可以使用较小的输出电容,同时将输出电压保持在允许范围内。因此,优化开关稳压器的响应速度可降低系统成本并减少电路的空间需求,因为可
[电源管理]
100V 隔离型单片反激式稳压器无需光耦合器
凌力尔特公司 (Linear Technology Corporation) 推出高压隔离型单片反激式开关稳压器 LT3511,该器件极大地简化了隔离式 DC/DC 转换器的设计。因为输出电压是从主端反激信号中检测到的,所以无需光耦合器、第三个绕组或信号变压器来实现反馈。LT3511 在 4.5V 至 100V 的输入电压范围内工作,具有一个 240mA、150V 电源开关,并提供高达 2.5W 的输出功率,从而非常适用于种类繁多的电信、数据通信、汽车、工业和医疗应用。
LT3511 以边沿模式、电流模式控制的开关电路工作,从而在整个电压、负载和温度范围内实现了 ±5% 的典型调节。相比于等效的连续导通
[电源管理]
多频技术改进数字电源转换效率并缩短设计周期
几十年来,电源转换器拓扑结构一直以模拟技术为基础。虽然大多数转换器采用开关技术和脉宽调制(PWM),但出于功率半导体器件在处理层面上的兼容,以及成本效益的考虑,电路构成主要为模拟。不过,这种情况正在改变。在显着提高数据中心和电信系统效率的过程中,模拟技术及其电路暴露出自身的缺点。
数字电源管理和控制提供实时智能,便于系统开发人员构建电源系统自动适应运行环境的变化,并优化每种特定应用场合的效率。智能数字电源IC可以自动补偿负载和系统温度的变化,利用自适应死区时间控制、动态电压调节、频移、相数降低和电流不连续模式的切换来实现节能。
数字电源给人造成费用高的感觉一直是其被快速接受的一个障碍,不过,最新推出的器件正在迅速消除模
[电源管理]
车用电源转换器的制作
在汽车内的点烟器插孔,只能获取12V的电压,但CD、液晶TV、MP3、游戏机等却需要不同的电源电压。下面制作的简单转换器可解决这一问题。
电路见图,12V电源从车载点烟器插孔取出,经二刀六位波段开关之一SW1A送入可调三端稳压器LM317的输入脚,LM317的调整脚(ADJ)经SW1B接入不同阻值的电阻到电源负端。当SW1在不同档位时,就可在输出端获得1.5V、3.0V、5.0V、6.0V、9.0V、12V几种电压,供相应的低压电器使用。LM317应安装在铝散热器(100×100×25mm)上,主要是因为在1.5V档时发热量较大。整个电路装入适当的小盒中,面板上只设波段开关即可。
图中R2"R6是输出电压设定
[嵌入式]
开关电源转换器新型电容器的开发
为了减小开关电源的体积和重量,必须设法提高电容器的性能,提高它的能量密度,并研究开发出适合于开关电源应用的新型电容器,要求电容量大,等效串联电阻(Equiva1ent SeriESResistance,ESR)要小,体积小等。据报道,美国南卡罗里那州KEMET电子公司在20世纪90年代末,已开发出330μF的新型固体钽电容,其ESR从原来的500 mΩ降低到30mΩ。
超容电容器(U1tra-CJapacitor)的开发应用也引起了人们的注意,超容电容器利用碳电极表面产生的双层电极,使其能量密度达到了0.2~10 W·h/kg,功率密度达到了100~5000W/kg,充电时间和放电时问各为0.1~100min,周期寿
[电源管理]
单电源转换为双电源的电路
单电源转换为双电源的电路
图1-39是采用TDA2030高效率运算放大器电路,利用其互补输出级将单电源转换成双电源的电路,它用于某些小功率电路所需要的双极性电源,电阻中阻值相等的R1.R2形成一个分压器,使上下两部分电压相等,分压器的中点接到运放的同相输入端,运放接成电压跟随器,使同相输入端和输出端电位相等,输出端又是虚地点,它与输入电源的地必须隔离,如果双极性电源直接从R1和R2上取出,则电源内阻大,负载能力差,使用运放后,两组输出电源具有很低的内阻,负载能力较强。
[电源管理]
LT3575 - 无需使用光耦合器的隔离型反激式转换器
描述:
LT ® 3575 是一款单片式开关稳压器,专为隔离型反激式拓扑结构而设计。无需借助第三个绕组或光隔离器来实现稳压。该器件可以直接从主端反激波形来检测隔离输出电压。一个2.5A、60V NPN 电源开关与所有必需的控制逻辑电路一起集成到一个 16 引脚 TSSOP 封装之中。
LT3575 采用 3V 至 40V 的输入电源电压工作,并能够在未采用外部功率器件的情况下输送高达 14W 的输出功率。LT3575 运用边界模式操作,旨在提供一款具改善负载调节性能的小型磁性解决方案。
输出电压能够很容易地利用两个外部电阻器和变压器匝数比来设定。许多应用可以采用市售变压器。
特点:
[电源管理]
高性能电源转换器设计中的同步整流技术
电源转换器的使用越来越普遍,电子设备制造商需要他们的电源系统不断增加新的功能和特性,例如更低的输入和输出电压、更高的电流、更快的瞬态响应。 为满足这些需求,在上世纪90年代晚期开关电源设计师开始采用同步整流(SR)技术——使用MOSFET来替代常用二极管实现的整流功能。SR提高了效率、热性能、功率密度、可制造性和可靠性,并可降低整个系统的电源系统成本。本文将介绍SR的优点,并讨论在其实现中遇到的挑战。
二极管整流的缺点 图1是非同步和同步降压转换器的原理图。非同步降压转换器使用FET 和肖特基二极管作为开关器件(图1a),当FET打开时,能量传递到输出电感和负载。当FET关断,电感中的电流流过肖特基二极管
[电源管理]
